TC25D Dash Lights
   / TC25D Dash Lights #1
MikePA
Super Moderator
PA
Had TC25D, now JD X310
Any Boomer owners have problems with the dash lights? I know there was a problem on some Boomers with fogging of the instrument panel, but don't recall reading of problems with the dash lights. I checked the 7.5 amp fuse and it looked fine, but I replaced it anyway. Still no dash lights.
   / TC25D Dash Lights #2
Mike, I don;t know if the setup is the same as on Class III boomers, but I have had a couple problems with 'in-line' connectors working loose. I know it is pretty tight under instrument panel, but you might check to see if their is such connection.
IndianaPaul
   / TC25D Dash Lights
Thanks, Paul. What's the easiest way to get under the dash, pull the panel or some other way?
   / TC25D Dash Lights #5
Mike, if your instrument panel is like the Class III Boomers, you just unscrew four phillips-head screws from the top and lift it out. It's "easy as pie."/w3tcompact/icons/smile.gif
   / TC25D Dash Lights
Jim, thanks for the tip. The TC25D has 2 screws, one on the left and one on the right, to hold the dashboard on. I took them out, pulled the dash panel out and found a whole lotta dirt on the back of the dash, probably from digging post holes in some very dusty ground. I blew the dirt off with all the lung power I could muster, and the lights came back on! /w3tcompact/icons/smile.gif
   / TC25D Dash Lights #7
Mike, my TC45D only has two screws also. I guess I'm getting old./w3tcompact/icons/frown.gif I thought I remembered four screws, but when I checked my tractor, it only has two./w3tcompact/icons/blush.gif It may even be the exact same part as yours. I'm glad you got your lights working./w3tcompact/icons/smile.gif
Year: 2008 (miles exempt on title) Make: Chevrolet Model: Malibu Vehicle Type: Passenger Car (A51694)
Year: 2008 (miles...
2007 Ford Crown Victoria Sedan (A51694)
2007 Ford Crown...
1997 INTL F-4900 (A50323)
1997 INTL F-4900...
2021 John Deere XUV835M Gator (A50514)
2021 John Deere...
Generac 5000Watt Heavy Duty Diesel Generator (A51691)
Generac 5000Watt...
2008 Suzuki XL7 SUV (A50324)
2008 Suzuki XL7...
