TC25 Losing Power
   / TC25 Losing Power #1
A72777
I noticed this at the end of about an hour of disking the other day. Today, I was bushhogging and after about 15 minutes the RPM just began to quickly drop. Engaging the clutch brought the RPM back to normal but engaging the PTO or transmission caused another drop in RPM. Yes, I'm talking about a significant and sudden drop. I limped back to the shed and shut down. Any ideas as to where to start in trouble shooting this? Thanks.
   / TC25 Losing Power #3
Also check and see if your air cleaner needs to be cleaned and open the hood and check the front of the radiator to see if debris has covered it..I know when I have bush hogged a lot of seed heads can actually cover the whole front of the radiator and it causes a power loss but so will a clogged air cleaner.
2016 Ford Escape SE 4WD SUV (A50324)
2016 Ford Escape...
2011 Nissan Titan SV 4x4 Crew Cab Pickup Truck (A50323)
2011 Nissan Titan...
CFG Industrial MH12RX (A50121)
CFG Industrial...
2018 John Deere 460E Articulated Dump Truck (A52748)
2018 John Deere...
20' Sea Container (A50774)
20' Sea Container...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50322)
2018 Toro Grounds...
