TC25 deal...or not?
   / TC25 deal...or not? #1
shakman
Central Texas
New Holland TC29
I have found what I think to be a fairly good deal on a NH TC25D. It includes the tractor, 7308 FEL, box blade, 5' shredder AND 16ft lowboy trailer for $15980+tax.
You can see the specifics at http://www.wctractor.com/tc-25_package.htm. I'm new to the whole tractor 'thing'. I just recently moved onto 10 acres and plan to do everything from grading my driveway to shredding to clearing cactus.
I guess my question is would this tractor do the job and is this a good deal for this tractor (for central Texas)?
Any and all input is greatly appreciated. Thanx to all who reply!
   / TC25 deal...or not? #2
I would think based on the info and the photos that the tractor isn't a hydrostatic (could be wrong though). Are you comfortable with a stick? or were you leaning to a hydrostatic?
Kevin
   / TC25 deal...or not? #3
Shakman, If the tractor is indeed a "D" model with hydrostatic tranny, I'd say it is a very good deal. On checking your link, I noted that the add didn't say "D" so I suspect it is a an 8 or 12 speed model. It still sounds like a good deal, but not quite as good as with the hydro tranny.
JimI
It turns out that the tractor is GST, not HST. That makes quite a difference in price (about $2500 more). The salesman told me that with the HST, you go up to the 'deluxe' model (hence the D after the TC25) where you get all sorts of other bells and whistles including a mid-PTO, a deluxe 3pt hitch, and other stuff.
I agree with you that it's still a good deal, but I think that my wife will want/need an HST to make it useful to her.
   / TC25 deal...or not? #5
Shakman, it sounds like you have been thinking through this pretty well. The Gear Shift Tranny (GST) is 9 fwd and 3 reverse instead of the 8/12 I mentioned earlier. When you consider that $2,500 is about an additional 20% on your tractor's price, it is significant enough to take you wife to the dealer and both of you "give it a go" on both types of tractors. That way you will always know you made the correct decision. I certainly favor the hydro tranny, but if you are not doing a lot of loader work, or if you plan to do a lot of plowing, the gear shift might be the best choice. The type of transmission is often the hardest decision to make because that extra $2,500 can buy a lot of nice attachments. Good luck in your decision./w3tcompact/icons/smile.gif
JimI
   / TC25 deal...or not? #6
I just purchased a TC29 with gear shift. I took my wife to try it and she actually preferred it. For our main uses I believe it will be an excellent machine. The TC29 is the only one of the 25, 29, 33 size to have a live PTO.
Bill
   / TC25 deal...or not? #7
<font color=blue>The TC29 is the only one of the 25, 29, 33 size to have a live PTO.</font color=blue>
Not according to my NH spec sheet: all of the "D" models in this series (TC25D / TC29D / TC33D) have a live PTO (I know my TC33D does). It also says all of the non-D models in the class II series have a transmission-driven PTO (I don't have easy access to one to verify this, however).
   / TC25 deal...or not? #8
John
You are absolutely correct. I should have worded it " the TC29 (not D version) is the only gear driven of the 25, 29, 33 class that can be obtained with Live PTO. The shift is on the steering column and after a test yesterday very handy for forward and reverse. I have driven stick machinery forever and just feel more comfortable and this makes a good combo - handy shift that you can basically shuttle and also keep the PTO running.
BillH
Thanx to all who responded to my initial message. With your help, I am now the proud owner of a brand new TC29! It's a great mule. I have already logged 2.5 hours on it doing some shredding at the house.
I ended up going with the GST instead of the HST. I found that the GST isn't nearly as complex to use at I initially thought it would be. My wife even finds it easy to use. I just couldn't justify the extra $2500 for the hydrostatic and the other features.
The package I got included the TC29, 5' shredder, 5' box blade, deluxe 3pt hitch, sealed tires, and a 16ft trailer. Out the door cost was $16500 with free delivery to my house (2 hours away from the dealership!) All in all, I think I got a pretty good deal.
Once I get my film developed, I'll make sure I post some pix of my new toy!
Miller Spectrum 500 DC Plasma Cutting System (A54811)
Miller Spectrum...
CATERPILLAR 312E EXCAVATOR (A52706)
CATERPILLAR 312E...
72'' ROCK GRAPPLE (A55787)
72'' ROCK GRAPPLE...
TORO TRX-20 WALK BEHIND TRENCHER (A51406)
TORO TRX-20 WALK...
2013 Ford Edge (A54815)
2013 Ford Edge...
UNUSED EINGP F10 - 10' WROUGHT IRON SITE FENCE (A54757)
UNUSED EINGP F10 -...
