TC24D loses power
   / TC24D loses power #1
jlema
2007 New Holland TC24d
I changed the fuel filter and bled the system and it started and ran but would not go to full revs. Then it just died. Anyone know what might have happened?
   / TC24D loses power #2
You don't have all the air out of the system. Bleed it again. Crack the lines for the injectors at the injectors. Did you turn the fuel back on.
Bill
   / TC24D loses power
I didn't bleed the injectors but it ran for about 4 or five minutes before it started slowing down and then dying. I thought all the air would be gone because it ran that long. But I will retry everything and bleed injectors this time. Thanks.
   / TC24D loses power #4
I agree with Bill. Probably, there was an air gap at the top of the filter that got pulled into the injector pump a little while after you re-started the engine. I'd do a good bleed of the system and try again.
   / TC24D loses power #5
Start at the filter and make sure that you bleed all the air out of it . Then go on to the pump, if it has a bleeder, and then to the injectors
   / TC24D loses power
Thanks for the advice. I hope it's gets warm enough in a little while to get it running.
New/Unused CFG Industrial MX15 RX Mini Excavator (A51573)
New/Unused CFG...
2008 John Deere 608C combine head (A50657)
2008 John Deere...
2024 JOHN DEERE CP 770 LOT NUMBER 21 (A53084)
2024 JOHN DEERE CP...
BROWN MPT-30 LOT NUMBER 67 (A53084)
BROWN MPT-30 LOT...
2018 JLG 4045R 40FT. Electric Scissor Lift (A51691)
2018 JLG 4045R...
2018 JOHN DEERE 50G EXCAVATOR (A51246)
2018 JOHN DEERE...
