TC21DA Boggs Down in High Gear
   / TC21DA Boggs Down in High Gear #1
louie339
New Holland TC24da
My TC24DA will not go up a slight incline on a paved road while in high gear. Even on flat surface I need to press the forward pedal as hard as possible to get any speed at all. The low gear does not seem to have this issue. I have owned the tractor for 14 years and this is a very recent issue. Any suggestions will be greatly appreciated.
   / TC21DA Boggs Down in High Gear #2
Have you changed your hydro filter and fluid in the past 14 years? If so when was the last time you did?
2012 RAM 5500 (A52472)
2022 Globe Trailers 53ft 65-Ton Tri-Axle Lowboy Trailer w/ Stinger (A50323)
2022 Globe...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
2016 Ford F-550 4x4 Ext. Cab and Chassis Truck (A50323)
2016 Ford F-550...
INOP/NON-RUNNING Chevrolet Rollback (A51572)
INOP/NON-RUNNING...
2015 KENWORTH T800 (A52472)
2015 KENWORTH T800...
