speters
- Joined
- Jul 10, 2014
- Messages
- 9
- Location
- SE Michigan
- Tractor
- John Deere GX335, Kubota ZD21, New Holland TC21D
I have a 2002 TC21D that I purchased used 2 years ago. It is just shy of 1300 hours. I haven't used it all that much. This spring I put a new fuel filter and glow plugs in because when it would start it seemed to run a bit rough for a while longer than my Kubota ZD21. It has ran great ever since until this past weekend. It took several attempts to get it started. It turns over great, is getting power to the glow plugs, and emits white fumes from the exhaust (unburned fuel I assume) while trying to start. Every now and then it will cough like it wants to start. I did get it to start and used it to brush hog for appx 2 hours with no problems. Then yesterday I tried to start it and had the same issues. So...since it has been setting idle for a couple of months I drained the fuel and put in fresh. I pulled the sediment bowl and drained it, refilled with fuel and bled the line at the banjo bolt on the fuel pump. Same results when I tried to start it. I'm thinking my step should be to pull the glow plugs and see if they are good and do a compression test while they are out. I bought the glow plugs (not OEM) on ebay. The first few times I started it after installing them it fired right up. It has always ran well with no noticeable loss of power. Any suggestion?
Thank you!
Thank you!
