TC18 Starting Problem
   / TC18 Starting Problem #1
BuzzyG
Bronze Member
My 2003 TC18 with 350 hours suddenly won't start. The glow plug light does not light, and at times, the other dashboard lights don't even come on. When they do come on and I try to crank it, they don't come on the next time I turn on the ignition. There is not starter action at all when I try to crank it, and only sometimes do I get a clicking sound from the relays.
The lights don't work at all, and everything except the sporadic dash lights (oil and battery) seems dead.
I have had the battery tested for voltage and short, and it is good. I get the same readings from the cable ends as I do at the battery terminals, so I don't think it is the cables or corroded terminals, but I have also cleaned the terminal connections at both ends of the battery cables.
I am really stumped. All suggestions will be gratefully received.
   / TC18 Starting Problem #3
It does sound like an intermittent connect such as bad cable, bad ground, battery terminals etc. Recheck everything as connection can look better than they really are. Another possibility is a battery post coming loose.
   / TC18 Starting Problem #4
check connections at main fuse, usually located by starter. Make sure your ignition switch is good.
I have the ignition switch out. How can I test it? Or how can I test the tractor to see if it starts by going around the ignition switch.
BTW - I replaced both battery cables and completely cleaned the posts and other connections.
   / TC18 Starting Problem #7
If the battery is good and the cables are new and the connections are good, that leaves the key switch, the solenoid or the starter OR an interlock (pto enaged, seat switch, clutch switch transmission switch, etc). Check the ground also.
How can I test any or all of those?
I know nothing about these.
   / TC18 Starting Problem #10
Jumper them one at a time. When you get the bad one, the tractor will turnover. You can check th starter switch by turning to different positions and measuring the voltage between the battery connection on the switch and the various lugs.
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2013 Ram 1500 Pickup Truck (A51692)
2013 Ram 1500...
2011 Toyota RAV4 4x4 SUV (A51694)
2011 Toyota RAV4...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
2015 FREIGHTLINER SPRINTER VAN (A52576)
2015 FREIGHTLINER...
2014 Great Dane 53FT Refrigerated Van Reefer Trailer (A51692)
2014 Great Dane...
