3-Point Hitch TC18 Spring
   / TC18 Spring #1
BuzzyG
Bronze Member
This forum has been invaluable to me already, and I have only had the machine for a couple of months. Thanks to all who haunt this forum and lend their expertise so freely.
My TC18 has a large spring dangling under the tractor from the right side of three point hitch. I can tell where the loose end is supposed to be connected by looking at the other side. But the spring is so large that I can't yet imagine a means of getting it stretched to the point that it reaches its intended location.
What does this spring do and how can I get it reconnected?
   / TC18 Spring #2
The only spring I can thing of is for a MMM. Can you post a picture?
   / TC18 Spring
I confess to being a novice. What is an MMM?
   / TC18 Spring
If it's mid-mounted mower, there is one of those on the tractor.
   / TC18 Spring #5
If there isn't a mid mounted mower, it is probably left from when one was mounted previously.
   / TC18 Spring #6
Yes, MMM refers to Mid-Mount Mower. If it is the spring I'm talking about, they can be a beast to get back in place. Do you have the installation manual for the MMM? I had the cotter pin wear one time and let that spring slip off. I also had one installed incorrectly by the dealer. So I'm well aware of the trouble to get these things back in place. I actually have the cotter pins on my list of things to check now and replace them and the retaining washer about 1 a year or so.
I wish I remember exactly what you have to do to get tha spring in place, but I don't remember. I know it included taking the mower deck off and then raising the 3 PT. hitch. and then LOTS & LOTS of tugging and pulling.
If you don't have the installation manual, let me know, and I'll see if I can find a page or 2 for the directions.
2013 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A50323)
2013 Chevrolet...
2017 Kawasaki Mule 4010 4x4 Rescue Utility Cart (A50322)
2017 Kawasaki Mule...
2020 KUBOTA SSV75 WHEELED SKID STEER (A51242)
2020 KUBOTA SSV75...
2013 Mack GU713 T/A Vac-Con Combination Sewer Jetter Vacuum Truck (A50323)
2013 Mack GU713...
2021 HAMM HD+9I VO DOUBLE DRUM ROLLER (A51242)
2021 HAMM HD+9I VO...
2011 Capacity Yard Jockey (A47384)
2011 Capacity Yard...
