rodster
I have a tc18 from 1999 with about 750 hours on it. The last time I cut my grass, it started to overheat. Thinking it was the radiator screen and fins being clogged. Cleaned everything up, but that didn't fix the issue. Now when I start it, within 10 minutes or so, the temp starts to head up. I'm thinking it is either the thermostat or water pump. No fluid leakage. I was looking at a parts list, it looks like I need to take the water pump off to change the thermostat. Does anyone know if that is the case? I'm more of a shade tree mechanic where I would normally swap the thermostat first and then go for the water pump. But it looks like there is a couple hours of work to the job. Any thoughts are appreciated.
Rodster
Rodster
