TC18 Instrument Cluster
   / TC18 Instrument Cluster #1
kyalpacas
Louisville, KY
JD 3320
My father purchased our old TC18, and the instrument cluster glass is broken. Guages all were working but now the RPM and Temp Guage doesn't. Is there a place where we can buy a used or aftermarket Instrument Cluster that will fit. Tractor is a 2002 and the dealer wants over $500 to order a new one.
Thanks for your input!
   / TC18 Instrument Cluster #2
The glass would be easy enough to replace. Just get some plexi glass and cut to fit. The rest not so simple. You could always take the instrument panel off and take it to the dealer to check. There is a proceedure in the service manual to check the electrical connections. I've had mine off to repair damage from mice. Just remove the center bolt from the wheel and use a small puller to get it off. The instrument panel only has a few screws and clips holding it in.
Solo
(1) RYOBI 212CC GENERATOR (A51248)
(1) RYOBI 212CC...
JOHN DEERE 5125R (A53084)
JOHN DEERE 5125R...
LMC LOT IDENTIFIER 238 (A53084)
LMC LOT IDENTIFIER...
2019 RBR Venturi 380 (A53472)
2019 RBR Venturi...
UNUSED HURRICANE D6028 - 5' JOB BOX (A51248)
UNUSED HURRICANE...
2024 Dig Master DM100 Mini Excavator, NEW! (A52384)
2024 Dig Master...
