TC 48DA & Woods 840 Bush Hog
   / TC 48DA & Woods 840 Bush Hog #1
Crisswell
Bronze Member
Butler County, PA
New Holland TC 48DA
Hi All.
I need some reassurance.
I ordered a 7' Woods 840 medium duty bush hog for my new TC 48. According to the specs for the both the tractor and the hog, it should make a happy marriage - But I just went by the Woods dealer and my new Bush Hog is in. WOW!!! Is that a beefy looking piece of equipment!! :eek: Just looking at it I wonder if I over-bought??
Weights in at 1280#, plus another hundred or two for the optional second wheel I bought. PTO is good at 540rpm, but I'm concerned about moving that hunk of iron around!?! Tractor specs say it can lift 3,465#'s, 24" behind the Cat 2 balls, and the Woods specs say a minimum of 40 tractor HP so I assume I'm good to go. But it would be nice to have some reassurance from some folks with experience.
Will I need front end weights?
Thanks.
Andy
   / TC 48DA & Woods 840 Bush Hog #2
With your loader on you should be ok . Without it , well you might want to keep the tail wheels on the ground
   / TC 48DA & Woods 840 Bush Hog #4
I have the woods 720. If i remember correctly it weighs near 1150 lbs. With the FEL on i`ve never had any problems.I even use it for a counter weight when lifting very heavy loads with the FEL.The rear tires never leave the ground.I`ve never removed the loader so cannot say how it will be if not attached
   / TC 48DA & Woods 840 Bush Hog #5
I think you will be fine.. though front weight will help.. your loader should be good weight.
I run a 10' 3pt mower on a ford 5000. I know that is a few more horses than your 48.. but the 10' mower is also 2500#. I have 420# of suitcase weights up front. it's fine for moderate teraine. if I has in big hills and vallies.. i think I'd throw another 200# on and call it good and safe.
Soundguy
Crisswell said:
Hi All.
Thanks.
Andy
   / TC 48DA & Woods 840 Bush Hog #6
I don't know what model my bush hog 5' rotory cutter is, but my TC55DA has no problem working with it. Never tried to cut with the loader off, but I guess I have to try that some day.
Thanks, Guys! I feel alot better now!
What a great resource this site is!! :cool:
Andy
   / TC 48DA & Woods 840 Bush Hog #8
Crisswell said:
Hi All.
I run my 6 foor Bush Hog with a TN70A. works fine. 70 HP. enjoy your setup. I can run in second gear in 3-4 foot grass. 1st gear for 7 foot grass.
Bob
2019 JOHN DEERE 5090M LOT NUMBER 92 (A53084)
2019 JOHN DEERE...
2018 Bobcat T595 (A47384)
2018 Bobcat T595...
2018 JOHN DEERE 672 GP (A52472)
2018 JOHN DEERE...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
2016 GMC Sierra Pickup Truck, VIN # 1GTN1LEC5GZ901362 (A51572)
2016 GMC Sierra...
FIRESTONE 9.5L-15 4 RIB TIRES (NEW CONDITION) (A53472)
FIRESTONE 9.5L-15...
