tc 48 wont turn over
/ tc 48 wont turn over #1
donatv
wells maine
new holland tc48
was using the tractor for about an hour, shut it off, about 5 minutes later it would not turn over, battery bench tested good, checked fuses and fusible link at starter, tractor has about 100 hours, noticed the glow plug light doesn't come on when key is turned to that position either, what do i do next
/ tc 48 wont turn over #2
Check your battery cables for corrosion at the terminal ends but internally as well. check your ground as well for tightness and corrosion. Check all safety switches , seat, PTO, Neutral etc. be sure you are in neutral speed and gear and PTO is off and check your fuses if you have not yet done so...good luck
2017 Case CX145D (A62177)
2017 Case CX145D...
Tufline PT 12' Box Blade (A64119)
Tufline PT 12' Box...
3PT 10' Rolling Cultivator (A60462)
3PT 10' Rolling...
Heavy Duty Booster Cables (A59230)
Heavy Duty Booster...
HARGEE 18' BOGGIE AXLE METAL TRAILER (A63291)
HARGEE 18' BOGGIE...
Bobcat T66 (A60462)
Bobcat T66 (A60462)
