B52528
After 10+ years with no problems with my TC I am coming to you with the first. Used my tractor for 2-3 hours this past weekend with no problems. Running down road back to barn it shuts down. Turn the key and nothing. Lights and flashers work fine. I checked the two connectors under the brake side of platform that are prone to separate and they were fine. Removed dash panel and replaced #2 fuse from left. Left panel open and turned key and watched it pop. I checked connections on tractor, battery, etc. Replaced fuse again, turned key and 'pop' again. Increased fuse from 10 amp to 15 amp, turned key and 'pop'. Towed tractor the 1/4 mile back to barn yard and decided I needed to consult others. It is now coated in 1/2" of ice since I could not get it in the barn, so it will be a few days before I can tend to it. Any suggestions on where to start looking for the short? Any harm in jumpering past the starter solenoid to see if it is the problem, or is there a wiser path to follow? Thanks in advance!
