tc 45 vs 40 da
   / tc 45 vs 40 da #1
boomerfun
I am looking for a boomer bus i am doubting between a tc 40 da and a tc 45 da, a friend of me said to buy the tc 40da because it has a lot of power, much cheaper and the with the hydro there is only a little difference between the 2
i will pull a mower for lawn mowing how big can i go wtihout forcing the engin and transmission ?? ( i will use the tractor fo a long time /forums/images/graemlins/wink.gif)
   / tc 45 vs 40 da
btw can i use plow 2- 14 with the R4 tires when it isn't to wet and is this damaging my hydro
   / tc 45 vs 40 da #3
what's the price of a 16 loader (tc40-45)
   / tc 45 vs 40 da #4
</font><font color="blue" class="small">( btw can i use plow 2- 14 with the R4 tires when it isn't to wet and is this damaging my hydro )</font>
I purchased a TC40DA last spring with R4 tires. I used it to plow with a 2-14 in heavy clay this fall. It worked great. I suspect you will be happy with either tractor.
   / tc 45 vs 40 da #5
</font><font color="blue" class="small">( what's the price of a 16 loader (tc40-45) )</font>
About $4000 U.S. if the tractor is "loader ready." If the tractor is not sold "loader ready" then the loader will probably be closer to $4700 because the joystick and plumbing have to be added.
   / tc 45 vs 40 da #6
</font><font color="blue" class="small">( I am looking for a boomer bus i am doubting between a tc 40 da and a tc 45 da, a friend of me said to buy the tc 40da because it has a lot of power, much cheaper and the with the hydro there is only a little difference between the 2
i will pull a mower for lawn mowing how big can i go wtihout forcing the engin and transmission ?? ( i will use the tractor fo a long time /forums/images/graemlins/wink.gif) )</font>
If you want to pull the largest mower, then the extra PTP HP of the TC45DA might come in handy. Personally, I would not pull a rotary cutter over 6 ft, but with either tractor you could go to 7 ft without much difficulty. For an 8 ft cutter, I'd stick with the TC45DA because of it's additional PTO HP and engine torque. For finish mowing, someone else may be able to tell you more info, but I'm just not that familiar with how much power finish mowers take.
The TC40DA and TC45DA are identical in every other way but PTO HP, so if you don't think that it's worth the extra money for the TC45DA, I'd have to agree with you.
   / tc 45 vs 40 da #7
Seems I almost always agree with the wisdom of our great NH Boomer guru, Jim, and this is just one more instant. I have a 40D and it has all the power I ever needed. As he says, unless you need more PTO power, I think the 45 would probably be unneeded. The transmissions, being identical, are such that you will never be able to put the extra 5 hp to the ground.
PACCAR PA56 WINCH (A51247)
PACCAR PA56 WINCH...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
UNIVERSAL WOLVERINE PFF2-13-45W QUICK ATTACH MAST (A51248)
UNIVERSAL...
(INOP) NEW HOLLAND TS6.120 TRACTOR (A51247)
(INOP) NEW HOLLAND...
UNUSED AGT QUICK ATTACH 72" VIBRATORY ROLLER (A51248)
UNUSED AGT QUICK...
2016 Big Tex 14LX 14ft 7 Ton T/A Dump Trailer (A50322)
2016 Big Tex 14LX...
