tc 45 da vs tc 48 da
   / tc 45 da vs tc 48 da #1
boomerfun
What is the best chose
In first case for mowing but straight lines and only a few trees.
And FEL work ( a bit and not in narrow places ) clutch wear??????
and at least tillage (6 foot and 8 inch deep)
   / tc 45 da vs tc 48 da #2
For mowing, tilling, etc... I would go 45da... It has the option of being hydro ? I believe so, where I know the 48 does not.
Those operations sound like you need a Hydro.
FEL still requires a reply, but I have not enough knowledge on the 45da to comment.
   / tc 45 da vs tc 48 da #3
Without knowing the size of your playground, and the fact I have only had my TC45DA for less than a month, I can tell you the TC45DA is a hydro.
I find the FEL very manourerable and it functions great .(once you get the hang of it) /forums/images/graemlins/grin.gif
Steve
   / tc 45 da vs tc 48 da #4
now i have a tce 50 and before this i had a tc 45da
i've the same needs as boomerfun only no fel work.
The manual transmission is no problem for me, i mow the most of the time straight lines but i mow in narrow places too, put my rpm at 1500 and take a low gear en let's do it
With my tc 45 i mowed here at the speed of 1 turtle
But in europe there is a big difference between some NH products.
I could buy a tce 50 + cab for the pirice of a tc 40 da with SS
so hydro is maybe a bit easier but after a time of practice a gear drive transmission is nearly as easy as a hydro
i am happy with mine.
BTW if you drive straight lines you will use the cruise control i guess, so it is +- the same as chose a gear and drive
/forums/images/graemlins/smile.gif
if you have more questions about it everyone may ask it /forums/images/graemlins/grin.gif
   / tc 45 da vs tc 48 da #5
btw: the hydro of the tc 45 da is very good, but there are a lot of cons
i don't now your situation but if you have a little mower you could mow around the trees.
btw have maybe a look at the landini mistral = Nh tce
I saw that my post was a bit strange
so i will repeat it:
New boomer: TC 45 da or a tc 48 da
- in first case for mowing on long srtaight lines, with a few trees, and i mow around the trees with my zero-turn ==> no shifting game around my trees /forums/images/graemlins/grin.gif
the other work is work for gears /forums/images/graemlins/laugh.gif tilling, transport,hay making,...
I prefer the tc 48 da because it is more tractor as the tc 45
Conclusion: i will only know something about the transmission, and is my opinion about the tc 48 true
   / tc 45 da vs tc 48 da #7
Well it depends on what you are mowing. I like the 45 for it's being more lightweight (If I recall correctly). As far as tilling, I prefer Hydro for that application.
Ground Engaging I do like Low Gears with a bigger heavier tractor. Plowing etc.
I think Jinman once had a good discussion on the FEL comparisons between the two....
Personally I believe the heavier tractor is not good for most people. It has a hard footprint on the ground, it is a bigger pain to haul, etc...
But to each his own....
   / tc 45 da vs tc 48 da #8
I agree with you.
I like my 16*16 more as my hydro because it's a lot more fun to drive with the 16*16. You have a foot accelerator... and using your clutch and shift from forward to reverse is very easy.
When i used my hydro i used always the cruise control at the end so what is use of a hydro??? a modern transmission like my 16*16 is nearly as easy as a hydro and you have a lot of pros like a foot accelerator, and otherwise you will use the cruise control or you will be very busy to control the pedal by driving at a rough underground.
   / tc 45 da vs tc 48 da #9
Ohhh, would you stop rubbing my nose in that sweet 16/16 trans you have in you TCE. I wish NH offered that option here in the states. My NH TC48DA would be a better tractor with another 4 lower gears. I calculated your 16/16, and your slowest speed is: 250 meters/hour = .155 mph. Swheeeeeeeeet! /forums/images/graemlins/grin.gif
UNUSED CFG INDUSTRIAL EXCAVATOR ATTACHMENT SET (A51248)
UNUSED CFG...
2015 JLG Triple-L Flatbed T/A Trailer (A50324)
2015 JLG Triple-L...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
66 Tomahawk Skid Steer Bucket (A52384)
66 Tomahawk Skid...
UNUSED SWICT 84" QUICK ATTACH BUCKET (A51248)
UNUSED SWICT 84"...
2016 Chevrolet Tahoe (A51694)
2016 Chevrolet...
