TC 40A vs 990
   / TC 40A vs 990 #1
flINTLOCK
Platinum Member
PA
NH TC40DA 2002
I'm looking at 4 WD CUT's for food plot preparation. Currently have 2 acres under tillage. Plan to gey to 10 or 12 acres eventually. Need to pull implements like shallow chisel plow, disc, rotary cutter, landscape rake. Ground has many rocks of all sizes. Will not have $$ for BH, but may be able to buy FEL in addition to others noted above. I've driven the NH TC40A and wanted to drive JD 990, but JD dealer had no 990's in stock. Any thoughts on comparing the 2 CUT's?? Really could use some advice!!
   / TC 40A vs 990
   / TC 40A vs 990 #3
</font><font color="blue" class="small">( I'm looking at 4 WD CUT's for food plot preparation. Currently have 2 acres under tillage. Plan to gey to 10 or 12 acres eventually. Need to pull implements like shallow chisel plow, disc, rotary cutter, landscape rake. Ground has many rocks of all sizes. Will not have $$ for BH, but may be able to buy FEL in addition to others noted above. I've driven the NH TC40A and wanted to drive JD 990, but JD dealer had no 990's in stock. Any thoughts on comparing the 2 CUT's?? Really could use some advice!! )</font>
Get draft control. Option for TC40.
Bob
   / TC 40A vs 990 #4
Bob
   / TC 40A vs 990
Thanks Bob, sounds like good idea. Overall capabilities of both machines reasonably comparable, you think??
   / TC 40A vs 990
   / TC 40A vs 990 #7
I've looked at both... but haven't seen a 990 in person, I just sit on the 790 and imagine it larger. Ergos are definitely better on the TC40. TC 40 has a more powerful loader and I don't think draft control is available on the 990. I believe the 990 is cheaper, but don't have a quote for one yet. The 990 has a more powerful engine and is more of a traditional tractor, as opposed to the modern TC40. It looks like the 990 sits lower to the ground... but it's hard to say without having seen one. I think the 4120 is more of a direct comparison to the TC40. The 4120 comes out on top in that comparison, but costs more.
   / TC 40A vs 990 #8
   / TC 40A vs 990 #9
The TC40 is a 40hp tractor, the older 990 were 40hp, but the newer ones are less hp, I think only 38. You should check up on this.
   / TC 40A vs 990 #10
2018 Nissan Titan Pickup Truck, VIN # 1N6AA1E57JN515039 (A51572)
2018 Nissan Titan...
VERMEER RTX130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX130...
2011 KENWORTH T800 (A52472)
2011 KENWORTH T800...
Quick Attach Skid Steer Plate (A51573)
Quick Attach Skid...
2013 Yamaha Golf Cart (A51573)
2013 Yamaha Golf...
2014 International Sweeper Truck (A52377)
2014 International...
