TC 40 da weight
   / TC 40 da weight #1
257NH
New Hampshire
New Holland TC40DA
I need to know the weight of my rig.
Its a tc40da with a 16la loader hd bucket with bolt on edge loaded rear r4s with rimgaurd.The manual is not really clear on this.At least to me.
   / TC 40 da weight #2
I think I can get close, but it will take a scale for the exact number.
Tractor - 3,500 lb
Loader w/Bucket and edge - 1200 lb
Loaded Rear Tires - 900 lb
About 5,600 lb total weight. I just call it 6,200 lb as a good round number when I have my 700 lb boxblade on my tractor. I don't think that is exact, but it's not too far off.
   / TC 40 da weight
Thanks for the reply Jinman,I used the 6200 figure when I registered the tractor today.Now I have to figure out where to put the plate.I'm also going to do the 50 hour tommorrow if I get a little time.
   / TC 40 da weight #4
Tractor - 3,500 lb
I was looking at the operator's manual for my TC40A the other day and on page 4-13 (specifications section) it says that the FWD weight (bare tractor) with ROPS is only 2,679 lbs. However, in the on-line specifications sheet, the weight of the TC40A is listed at 3,405 lbs (w/ ag tires). So, is the bare tractor weight the weight without the wheels on it? Or is one of the numbers incorrect?
   / TC 40 da weight #5
mundamanu,
By jove I think your right. I never looked at the on-line specs that closely before. It makes sense too from the standpoint of different wheel widths (& therefore weights) for the different style tires.
For the TC40DA, on line specs (with ags) is 4,026 lbs. I would think the weight could easily increase by a couple hundred for the wider R4 tires. (front & back).
Vic
   / TC 40 da weight #6
My tc40 manual says 2,860 lbs for bare weight of tc40da. the manual is dated 5/06 and is for PIN Number Z6DB01001 and Above. so i guess they weigh different weights over that last few years. bought mine 4th quarter 2006. i have a lot of plastic (hood, fenders, etc...). i expect a lot more weight if they were metal as an older model would have.. :)
   / TC 40 da weight #7
I think that "bare" weight must mean without tires and wheels. I believe the weight is 3,480 lb, approximately, dry weight. I just round it up to 3,500 lb.
2012 Chevrolet Silverado 2500HD Enclosed Service Truck (A52377)
2012 Chevrolet...
50ft Fuel Line (A51573)
50ft Fuel Line...
2009 Volkswagen Jetta Sedan (A51694)
2009 Volkswagen...
2021 BOBCAT T450 SKID STEER (A51246)
2021 BOBCAT T450...
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
INOP/NON-RUNNING 2007 Peterbilt 378 Flatbed Mud Mixer Truck, VIN # 1XPFDT9X37D666626 (A51572)
INOP/NON-RUNNING...
