TC-35D had loose bolts
   / TC-35D had loose bolts #1
farmacist
Bronze Member
Saranac, New York
TC35D
After 70 hrs and maybe at birth my TC35D (same as 40 and 45) had 3 out of 4 loose bolts. Check yours cause there is nothing worst than loose "nuts". There are 2 bolts, gold, (size 19) on each side of the "yolk" that holds the front drive shaft and the front axle to the gray frame. On the left they are between the exhaust pipe and the front axle housing and on the right they are below the hydrolic pump and below the bypass hose from the radiator to the block, but to the rear of the front axle housing. We should all be more dilligent at checking our nuts. Frank
   / TC-35D had loose bolts #2
I know I am getting old, but I swear I posted the same problem a few weeks ago, and now I can't find it. However, you are correct that this is a problem area. On my TC45D, I found two bolts backed out so that they were only finger tight. I'm sure glad I found it before the whole front end went "walk-about"./w3tcompact/icons/shocked.gif
JimI
   / TC-35D had loose bolts #3
New Holland does have a quality control problem, I lost all the hydraulic fluid out of my TN when the bolt that holds the lift arm pin came out, I was brush chopping and when I looked back the chopper was crooked and the oil was pouring out. I also had a power steering line leaking and the bolt that ties the remote to the joystick fell out. I hope NH does something about this and so far my dealer has no problems fixing these things but they are an inconvience at times.
<font color=blue>Robert Turk Jr.</font color=blue>
<font color=blue>Whitetail Splendor Deer Farms</font color=blue>
<font color=blue>Silver Creek, NY</font color=blue>
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52128)
80in HD Tooth...
Parker 250 bu Gravity Wagon (A50515)
Parker 250 bu...
Best 30' Grain Drill (A50514)
Best 30' Grain...
2020 ROLLINS 26' FG GOOSENECK TRAILER (A51243)
2020 ROLLINS 26'...
2016 Poulan Pro PP19A42 42in. Riding Mower (A49346)
2016 Poulan Pro...
2017 JCB 3CX 15HFCE BACKHOE (A51242)
2017 JCB 3CX...
