Oil & Fuel TC 35A power steering filter/canister
   / TC 35A power steering filter/canister #1
boatyard
western MASS.
2005 New Holland TC35A
The power steering filter/canister was due to be changed at 600 hours. The filter/canister is $75 at the local dealer. I checked with Messnicks and they want $86. Much cheaper then a new power steering pump, but is there a way to make an end run around that much money for a filter? New Holland parts prices often seem like a license to print money. I assume the other brands are also crazy expensive.
Thanks Christopher
   / TC 35A power steering filter/canister #2
I have 1700 hours on my TC45D and have NEVER changed the PS reservoir/filter. I'd bet that is pretty common. If you drain the fluid and put in new, you'll probably do more than most. Since the fluid is not in an engine and doesn't have much contamination, I'd bet it looks nice and clear when you drain it. I would not try to flush the filter either. Go with what you are comfortable with is my advice.
EDIT: Oh yes, on later models the PS reservoir/filter is completely eliminated. The PS pump draws fluid from the main hydraulic reservoir.
Thanks. I will give that a shot and see what the fluid looks like. I was just trying to spoil the tractor.
2003 Club Car DS Electric Cart (A51694)
2003 Club Car DS...
2012 Freightliner Cascadia - Class 8, 6x4, Detroit DD13 (A52748)
2012 Freightliner...
2015 Kaeser M114 100psi Towable Air Compressor (A51691)
2015 Kaeser M114...
2018 Ford Fusion Sedan (A51694)
2018 Ford Fusion...
2015 Great Dane 53FT Refrigerated Van Reefer Trailer (A51692)
2015 Great Dane...
