6sunset6
Veteran Member
- Joined
- May 6, 2007
- Messages
- 1,055
- Location
- SE NY
- Tractor
- NH TC34DA 34HP HST, 2 rear remotes, front diverter, loaded R4's
I have a TC34DA HST. The throttle has to be up at least 1/2 way to move around. All the way up do serious work. So it turns out the throttle is up at 2000 plus all the time. The TC35DA has two foot pedals forward and reverse. Question is are these tied to the throttle so less rpms until needed or is it the same as the 34 RPMs are up all the time.
Seems like not efficient use of fuel. I have a MF 30E BH that has two pedals , shuttle shift , and they are tied to the throttle. If you let off either pedal the rpm's return to idle. How about the EHSS? How does that work.?
I got the 34 because I did not want a bigger frame machine but now I am wondering.
