SpotsyChris
2003 TC 33DA, Manual Transmission, 14LA loader, 325 hours, located in Fredericksburg VA area. I used the tractor yesterday to put in some post holes and light barn work. Parked the tractor outside by the garage because we were going to use it again this morning. It got real cold last night, about 10 degrees, but that hasn't been a problem in the past. When we went to start it, it fired right up then the the engine started to rev up to max and I turned off the key. I checked the hand throttle and it seems stuck (at minimum) and won't move. The foot throttle seems to have full range of motion. I tried disconnecting the cable from the hand throttle and restarted and the same thing happens. As soon as the engine catches, it tries to go wide open. I tried again later with the temp up to the high 20s and it still is happening. Any suggestion? I am not a great mechanic and haven't done much to the tractor except routine maintenance. It has never had this type of symptom before.
