TC 33 Rear PTO Shift Lever Hard to Move
   / TC 33 Rear PTO Shift Lever Hard to Move #1
tkcomer
Maysville, KY
JD 3039R
Actually, I have a DX 33. Same tractor. I have the same problem as referred to in this post: http://www.tractorbynet.com/forums/new-holland-owning-operating/98153-tc33d-rear-pto-shifter.html The rear PTO shift lever is really hard to engage or disengage. But that post is from 2007. Can anyone verify that the spring number (398210280) that member jfomr mentions is still the same spring used to fix this problem? I see a replacement spring number as SBA398210280, but it really doesn't identify what spring it is. Online parts manuals show the part number as SBA398210460. Any help in this matter would be greatly appreciated.
Just to touch base, I ordered the SBA398210280 spring and installed it. What a difference. PTO lever moves a lot easier. Not hard to do either. With the tractor off, I did put the mid mount PTO in gear and removed the rod for better access. Then a 19MM socket took the plug off. Replaced the spring and put it back together. On a side note, while at the NH dealer, they said a guy that owns a TC-33 came in the week before and ordered the same spring. So if your rear PTO lever is hard to move, this is a cheap and easy fix.
2014 PETERBILT 388 (INOPERABLE) (A52472)
2014 PETERBILT 388...
706075 LOT NUMBER 81 (A53084)
706075 LOT NUMBER...
2012 CHEVROLET SILVERADO 2500HD (A52472)
2012 CHEVROLET...
2013 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2013 FORD F-150 XL...
MILLER BIG BLUE 500 PRO TOWABLE WELDER (A52472)
MILLER BIG BLUE...
2021 Chevrolet Silverado 4500HD / Silverado 5500HD Flat Bed, VIN # 1HTKJPVK3MH814615 (A51572)
2021 Chevrolet...
