TC 33 Fuel sender swap? any ideas how to
   / TC 33 Fuel sender swap? any ideas how to #1
Dirtball
Eastern, Pa.
NH TC33D
1999 TC 33D , fuel gauge stuck on full. Couldn't find any old posts covering how to replace sender. I know it may be the dash gauge or wire , but counter man send alot of calls repalcement senders. Thought I'd start here. thanks
   / TC 33 Fuel sender swap? any ideas how to #2
If you have a short offset screwdriver, the sender can be accessed and changed by removing the instrument panel & nothing else. We replace far more gaugees than senders in this application, probably 3:1 at least. If it is truly a gauge problem, it should go to empty when shut off, or when the sender wires are disconnected and the key is on. You can further test the sender with a VOM.
2014 CATERPILLAR 826G LANDFILL COMPACTOR (A51406)
2014 CATERPILLAR...
2013 Ford Transit Connect Van (A52377)
2013 Ford Transit...
2012 Chevrolet Silverado 2500HD Enclosed Service Truck (A52377)
2012 Chevrolet...
2008 VE 500 BBL FRAC TANK (A53843)
2008 VE 500 BBL...
2019 Kenworth T270 Rollback Wrecker (A53117)
2019 Kenworth T270...
LAPTOPS AND ASSORTED POWER CORDS (A53843)
LAPTOPS AND...
