tc 30 quick attatch????
   / tc 30 quick attatch???? #1
DaryleD
New Hampshire
BX 2660, NH Workmaster 55
Hi all! I am wondering if anyone has made or bought a quick attatch for their fel? I am debating making or buying one. The lift capacity on my tc30 is lower than the bigger tractors, so should I bother doing this where I might not be able to use the heavier skid steer stuff? If you folks think that it's worth it than how much for store bought ? Are quick attatch systems compatible with each other so that anyones quick attatch implement will fit any Q.A. system? If anyone has made their own do you have any pictures? If this tractor is too small, what would you do? Buy a bigger tractor? Thanks to all! /forums/images/graemlins/confused.gif
   / tc 30 quick attatch???? #2
I had one installed by the dealer when we got our TC40D and it has really come in handy switching between the bucket, pallet forks, and now the snow plow. You can use skid steer implements however most machines don't support enough hydraulic flow to use implements like a hydraulic post hole auger.
   / tc 30 quick attatch???? #3
You could look at the ATI pin quick tach. You can use the same attachment that you do now without having to use adapt plates on everything. You can't use the Bobcat products, but the pin system is lighter and a lot less expensive. I have had one for about 2.5 year and really like it. Things go on and off quick and easy, for less than half the price and no plates. If you want to look at what I am speaking about, they are in complete line catalog on ATIs site.
Thanks guys! I really appreciate the advice. I'm going to check out ATI and compare to the plate system. I am thinking the ATI won't affect my fel lifting capacity as much. Thanks again! /forums/images/graemlins/laugh.gif /forums/images/graemlins/grin.gif
2015 MACK GU713 DAYCAB (A50854)
2015 MACK GU713...
71050 (A49346)
71050 (A49346)
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
2016 Ford Transit Connect XL Cargo Van (A48081)
2016 Ford Transit...
2003 Ford F-150 4x4 Crew Cab Pickup Truck (A48081)
2003 Ford F-150...
ASSET DESCRIPTIONS & CONDITION (A51219)
ASSET DESCRIPTIONS...
