tc-30 hydro pbs.
   / tc-30 hydro pbs. #1
joeberry
la porte, texas
I have a new problem with my tc-30. I attached my new land-pride finish mower and adjusted all linkage. Raising the lift is fine but when I lower the lift, there is a bounce on the way down. I have had other implements on before and this has never happened, The fluid is ok and there is no binding in the linkage. I could not find any thing in the manual about this. PLEASE HELP, joe b.
   / tc-30 hydro pbs. #2
I think what the problem is, is that somehow your knob that controls the 3 point drop speed, has been turn in too far, which will restrict things enough to make it jump. The knob is the one with the rabit/turtle ( at least on mine ). It is located lower than the seat, between your legs, when sitting on the tractor. Move it to drop the implement faster and see if it helps. One other sugestion, is that you may not be moving the lever that drops your 3 point linkage, fast enough. Hope that solves your problem. Let us know when you do find it.
Daryle.
   / tc-30 hydro pbs. #3
Maybe the mower is heavier and /or sticks out further behind the hitch than your other impliments , than it's pretty normal for that to happen , my tractors have done it since new . Adjusting the flow down may help as suggested .
   / tc-30 hydro pbs.
oh ya, that's sweet. I got the drop adjusted and I swear I did not see anything in the book. It drops nice and slow and it is all good. Thanks for the advice .........jwb
UNUSED KIVEL 3500# PALLET FORKS (A51248)
UNUSED KIVEL 3500#...
UNUSED TOPCAT SSSCR72-72" HYD SOIL CONDITIONER (A51248)
UNUSED TOPCAT...
Kubota RTV 1100 (A51573)
Kubota RTV 1100...
20ft x 20ft Steel Carport (A51573)
20ft x 20ft Steel...
2015 Ford Escape SUV (A51694)
2015 Ford Escape...
