TC -29 hydraulic oil leak
   / TC -29 hydraulic oil leak #1
brin
Super Member
Georgia - Mt. Vernon by The Store just 5 miles eas
I have notice 3 small hydraulic oil leaks under my TC-29 . I got under there and found no leaks so I figured it was leaking from under the hood and then leaking back and dripping down in 3 spots. Sure enough under the power steering reservoir i wiped the hose real good and clean and came back a few days later and hydraulic oil was coating the hose that goes directly into the bottom of the reservoir. I have a FEL on it and getting in there to see what is going on is going to be tough. I am wondering if anyone else has had this problem and exactly what it is ...? O ring ? gasket ? and also wondering if I should just leave it alone and top it off each time with Hyd. fluid since it only leaks about 4 tablespoons a month or fix it ? Any thoughts ? Thanks..
   / TC -29 hydraulic oil leak #2
check hose clamp,if there is one,might be loose.
   / TC -29 hydraulic oil leak #3
cap and filter housing to.
soundguy
   / TC -29 hydraulic oil leak #6
My TC 40 has a replaceable power steering filter. If you can't stop your leak, maybe replace that filter while you have it in front of you and are working on it.
Dave.
ECHO PB-2520 GAS HAND HELD BLOWER (A51248)
ECHO PB-2520 GAS...
2025 IR UNUSED Ripper (A53117)
2025 IR UNUSED...
2008 Ford F-250 (A53473)
2008 Ford F-250...
ECHO SRM-225 GAS WEED EATER (A51248)
ECHO SRM-225 GAS...
HURRICANE 6' X 11' CONTAINER (A51248)
HURRICANE 6' X 11'...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
