TC 24D Oil Capacity
   / TC 24D Oil Capacity #1
kiphorn
Central PA
TC 24D
I'm getting ready to change the oil on my TC 24D. When I bought the tractor the dealer gave me a NH Lubrication Maintenance Guide. In the pamphlet the oil capacity is listed at 4.2 Qts. In the Operators Manual the capacity is listed at 3.5 Qts. Does anyone know which is correct? /forums/images/graemlins/confused.gif
   / TC 24D Oil Capacity #3
I was charged for 5 quarts on my 50 hr service, so I would think 4.2. Rick has the better answer with the dipstick. Put 3.5 in it, run it for a couple of minutes to make sure all the filters are full, then add as necessary to the full mark.
   / TC 24D Oil Capacity #4
<font color="blue"> Put 3.5 in it, run it for a couple of minutes to make sure all the filters are full </font>
I'd add 'Check the dipstick' before running it. /forums/images/graemlins/shocked.gif /forums/images/graemlins/smile.gif
I'd fill the oil filter before installing it (fill the filter just enough so it does not run out when you spin it on), plus it shouldn't take a couple of minutes to fill the filter, should it...just wondering?
   / TC 24D Oil Capacity #6
Ive done a couple changes on my 24 and both times it req'ed 3.5 qts...which agrees w/ my manaul.
   / TC 24D Oil Capacity #7
</font><font color="blue" class="small">( I'd add 'Check the dipstick' before running it. )</font>
Or the drain plug on the oil pan. No - I've never forgotten it....................on a tractor /forums/images/graemlins/blush.gif
   / TC 24D Oil Capacity #8
I was just out looking through the shed last night to see if I had oil to do an oil change this weekend. Guess what I found? A 4 quart jug w/ about a pint of oil in it. That tells me that I put 3.5 quarts in it last.
Now if the wife can remember to make it to the dealer today to pick up oil & fuel filters I'll be all set. Do those and change the antifreeze I should be good to go until spring.
Year: 2010 Make: Ford Model: F-150 Vehicle Type: Pickup Truck Mileage: 81,045 Plate: Body Type: 2 (A51692)
Year: 2010 Make...
2003 Ford Excursion 4x4 (MPV), VIN # 1FMSU43PX3EC07978 (A51572)
2003 Ford...
1999 LBT INC FUEL TRANSPORT TRAILER (A52472)
1999 LBT INC FUEL...
CHANDLER 20FT 16 TON HYDRAULIC SPREADER (A52472)
CHANDLER 20FT 16...
2014 Nissan Juke Multipurpose Vehicle (MPV) (A51694)
2014 Nissan Juke...
