TC-24D, lessons from the field
   / TC-24D, lessons from the field #1
SacandagaBrad
Platinum Member
Southern Adirondacks, NY
TC24D
Just did my 300 hr service and got thinking about some of the little tricks I have picked up along the way that I thought I would throw out there for anyone new to a Class I Boomer or thinking of getting a small CUT. Some of these I came up with during the 300 hr service (wasn't difficult at all), some are probably buried deep in the manual, some I picked up here at TBN, and some are just little back savers I have come up with. I'm sure others will chime in with their own tricks, if it saves some frustration or a few pinched fingers, then it was worth the typing.
Always take off the FEL on level ground and don't leave it out in the sun if you ever plan to put it back on during daylight hours. Those black hoses heat up and build up pressure to the point you will have to relieve it before reconnecting the hoses.
When removing and installing the 914A MMM, I have found having the rear gauge wheels set one setting higher makes it much easer to make the connections. Once installed, I set it to the corresponding setting. With the cushion lift system set up correctly to pitch the deck slightly forward, it makes it very tough for me to line up the pins with the deck on a level floor. A little expermentation might make things easier.
Make sure the left hand lift rod on the 3PH is pinned through the highest hole before mounting the MMM.
When draining the transmission, rear axle, and front axle, I removed the wheels for easier access. Also made changing the hydro filters a lot easier. My rears are loaded, still worth the effort. Block it up safely.
Rather than fight with the close, almost impossible angle of removing the retaining nut on the fuel filter, I removed the whole assembly by taking out the single bolt that holds it to the frame of the tractor, then rotated the filter assembly in my hand to get the channel locks on easily. Bolt takes a 12 mm socket. I guess it is only a royal pain if you have the FEL.
When you pick up your hydro fluid for the 300, the five gallon does it. But pick up a quart bottle as well that you can put a small hand pump on for filling the front final reduction gear cases. I used the one for my boat lower units, worked like a charm.
I considered not bothering with the front axle oil change at the 300 hr. Glad I kept moving, turned out that oil was the dirtiest of all the fluids, except of course for the motor oil.
Always use FWD with the FEL, not only gives you more power traction, but also front breaking power.
A 7' ROPS doesn't clear a 6 1/2' door.
Turfs work great in the snow as long as you have chains.
And I have yet to figure a better way to work the 3PH sway bars, what a PITA.
Take it for what its worth, just some things I have found to make life easier in the first 300 hrs of owning my tractor.
Brad
Brad
   / TC-24D, lessons from the field #3
I'll add this. Check all your fastners, last night I went out to regrade my driveway and found the bolt loose that connects the ROPS frame to the rear axle. This piece is also where the bottom of the lift arm connects to the tractor. I have also found wheel lugs loose and even lost 2 of them before.
Solo
   / TC-24D, lessons from the field #4
Solo
   / TC-24D, lessons from the field #5
</font><font color="blue" class="small">( And I have yet to figure a better way to work the 3PH sway bars, what a PITA. )</font>
You and me too!!! Of course now with the Pat's I find that I'm adjusting them less though I still had to yesterday for the cuttery as evening with the jam nut the cutter kept forcing them to loosen up.
I hadn't tried that with the fuel filter. I hate to change the filter because of that design I'll have to try your technique.
I'll give you my what I learned for the 300 hr. service. I used ramps for the rear and jack stands on the front (I had to reattach the MMM at the same time more on that later. When you are driving down off the ramps move the pan of used hydraulic fluid out from under the tractor as when the tires catch the edge of the drain pan, it will upset. /forums/images/graemlins/blush.gif /forums/images/graemlins/shocked.gif /forums/images/graemlins/grin.gif
Speaking of loosening up a couple of things I've learned that need to be checked: the mounting plate under the tractor for the MMM. Has 4 bolts that hold it up under the tractor. Mine has come out twice. Got really lucky the second time as 2 of the bolts broke off inside the house and I had to drill/E-Z out them out. /forums/images/graemlins/shocked.gif :cool The second one just happened yesterday while "Hoggin'," the bolt that holds the lift rod to the lift arm either came loose or broke (not likely). Couldn't figure out why I couldn't lift the one side of the little 4' King Kutter up. A lynch pin worked to get me back to the garage and quick trip to TSC got me going again. It isn't the right bolt, but it got me going and a trip to the dealer to get the right one this week. /forums/images/graemlins/laugh.gif
All in all though it was good day cutting yesterday the aforementioned lost bolt, 2 broken lynch pins (needed to turn the top link pin around and put in from the other side /forums/images/graemlins/confused.gif), only got stuck once and some sunburnt arms. So at least nothing major - Not bad for about 7 hours seat time. /forums/images/graemlins/grin.gif
   / TC-24D, lessons from the field #6
   / TC-24D, lessons from the field #7
I sure agree with you comments about the fuel filter. The TC-23 is set up the same way. A two minute job took about an hour. The bolt that held the fuel filter assembly on the bracket was very tight and I bent the bracket getting the filter off. Looking at the set up, there is plenty of room for NH to move the fuel filter up higher on the firewall where it would be easy to service the filter. I thought about doing it myself but noticed there is not enough fuel line to move it. One other thing to check for those of you with MMM -after the first 1 1/2 hours of use, I noticed one of the bolts that holds the gear box to the mower frame had come loose. I took all of the bolts out and put some thread lock on them.
   / TC-24D, lessons from the field #8
   / TC-24D, lessons from the field #9
I did the fuel filter tip this past weekend. Worked pretty well. I was able to loosen the fuel filter move it up and took the nut off by hand and then put it back together by hand. Only took me maybe 10 minutes to change the fuel filter - 5 minutes of that spent cleaning the little plastic bowl up. Had quite a bit of gunk in the bottom - more than normal.
Another thing I learned. Make sure the bolt that attachs the lift rod to the lift arm is tight. I lost or broke mine a couple of weeks ago while bush hogging. Had my F-I-L pick it up for me at the dealer. $18 /forums/images/graemlins/ooo.gif /forums/images/graemlins/mad.gif for a bolt with a shoulder. /forums/images/graemlins/mad.gif /forums/images/graemlins/ooo.gif /forums/images/graemlins/crazy.gif /forums/images/graemlins/confused.gif Had I known that I would have continued using the bolt I picked up from TSC - it just didn't have the shoulder so it didn't tighten as nice.
   / TC-24D, lessons from the field #10
2015 KUBOTA M9960 LOT NUMBER 214 (A53084)
2015 KUBOTA M9960...
1995 Chevrolet K2500 Pickup Truck, VIN # 1GCGK29F2SE237154 (A51572)
1995 Chevrolet...
2013 MACK GRANITE (A52472)
2013 MACK GRANITE...
1263 (A50490)
1263 (A50490)
Turfco Mete-R-Matic III Pull-Behind Top Dresser (A51691)
Turfco...
16ft T/A Flatbed Equipment Trailer (A50322)
16ft T/A Flatbed...
