TC-24 (or any NH Class I) Owners - I Need some help
   / TC-24 (or any NH Class I) Owners - I Need some help #1
SacandagaBrad
Platinum Member
Southern Adirondacks, NY
TC24D
Anybody have trouble with wind-up tension on the drive train while in FWD? My 24D has started to bind up to the point where I have to back up a few feet to relieve the tension before switching the transfer case back to 2 wheel drive. Tire pressures are even, fluids are up to proper levels, and this is on grass and gravel roads. Machine is a 2003 with about 435 hours, never had trouble before a couple of months ago when I started to notice it.
Brad
   / TC-24 (or any NH Class I) Owners - I Need some help #2
I just looked at my service manuals and I can't find anything in the trouble shooting guide. If you figure out the problem let us know.
Solo
   / TC-24 (or any NH Class I) Owners - I Need some help #3
I don't own those machines but have owned other NH cut's that were 4wd.
As long as I was on grass, the 4wd engage / disengage was easy, especially if I did just pop her in R and roll an inch.. But on any kind of high traction surface.. you may have more significant problems with wind up and premature tire wear ( scuffing )..etc.
If this is a new unit.. it may simply just shift a bit stiff till it gets broke in well.
soundguy
Soundguy,
Its not new, in fact it used to be smoother. I can disengage at any time, it just has a lot of tension on it unless I back up a little, like you said. It just doesn't seem like it should develop this as it gets older and broke in. I'm worried about premature wear and tear. I was hoping it was something simple like an under inflated tire. Maybe its normal?
Brad
   / TC-24 (or any NH Class I) Owners - I Need some help #5
If your tire sizes have changed drastically.. ie worn down ont he front, your rolling ratio's will have changed.. thus making more misfitt on the driveline.. etc.
Soundguy
   / TC-24 (or any NH Class I) Owners - I Need some help #6
If you have a FEL on the tractor, you can take the pressure off by picking up the front end.
   / TC-24 (or any NH Class I) Owners - I Need some help #7
Front tires always wear quicker than the rears do to the gear ratio not being identical. When fronts wear before rears this problem will begin to be noticed more.
   / TC-24 (or any NH Class I) Owners - I Need some help #8
Brad,
I have a 24 and have the same exact scenario. I shift from 2 - 4 - 2 all of the time. I usually stop when going from 2 - 4 (but not always), but because of the wind-up I usually shift from 4 - 2 on the fly. If I've been turning I or something the lever is real tight, but if I drive in a straight line (forward or backward) you can literally rest your hand on the lever and feel it free up and it will slip out of 4wd. Mine has been that way since new. I believe this is normal operation for these tractors. I don't think you have a problem.
   / TC-24 (or any NH Class I) Owners - I Need some help #9
my class 2.... how stiff it shifts in and out has to do with the postion of the front wheels and what kind of surface im on.
sometimes it slides in and out with out any noticable force on the lever.
other times im fighting it and have to straighten up and backup before it will disengage.
Jim,
That's how mine used to be, but now it winds up even in a straight line. I can turn right and left and that relieves it, or back up, and either way it slips right out of 4wd with minimal effort. Its no so much that I think it is a major problem, just that is a change so I'm wondering if it is a sign of something more serious. Maybe I'll play around a little more with tire pressure on the front, other than that not worry about it.
From what others have posted, it sounds within normal operation limits. My neighbor's older Kubota winds up so tight, he has to back it up to get it to release sometimes.
Brad
(2) VISSANI REFRIGERATORS (A51248)
(2) VISSANI...
JOHN DEERE HPX GATOR 4x4 *NOT RUNNING* (A50324)
JOHN DEERE HPX...
2022 Adams CLC-1013 Conveyor - New (A53472)
2022 Adams...
UNUSED CFG QUICK ATTACH HYD POST DRIVER (A51248)
UNUSED CFG QUICK...
JOHN DEERE 7300 (A53084)
JOHN DEERE 7300...
