TBN Poll - Best Leave Removal Method
   / TBN Poll - Best Leave Removal Method #1
JohnnyD
Allright guys. Many of us cant just grind up our leaves with the mower deck, or blow them from point A to B. We actually have to move piles that we make with a leaf blower to some other spot. So what works for you? Pulling tarps with the tractor? A big plywood box that somehow is attached to the FEL? Lawn vacs? Maybe you have an ingenious method. Enlighten us that struggle this time of year and are convinced there has got to be an easier method. John
   / TBN Poll - Best Leave Removal Method #2
Johnny -- I use a chicken tractor mounted to the FEL. Basically a 4x8x3 frame with chicken wire (used as a portable pen). It can handle a lot of volume but not much weight, so it's perfect for moving leaves. I know Corm uses a plywood scoop thingie to extend the bottom and sides of his loader bucket. Doesn't hold as much but is far easier to load up and dump than mine.
Pete
   / TBN Poll - Best Leave Removal Method #3
I don't guess I ever found an easier way either. I just set two 55 gallon plastic barrels in the front end loader, filled them up, took them and dumped them in the garden, then tilled them in.
   / TBN Poll - Best Leave Removal Method #4
Manually, the best way (I have found) is to spread out a large bed sheet, rake the leaves onto the sheet, lift all 4 corners together, and trek off like Santa Claus to your burn pile, or dumping area.
Ho Ho Ho
   / TBN Poll - Best Leave Removal Method #5
Over time, I have found it easiest to lift the receiver off the hook, dial the landscaping service, and then write a check. Just kidding...I actually enjoy raking leaves and I use those big green plastic barrels.
   / TBN Poll - Best Leave Removal Method #6
Leaf removal for me consists of at LEAST three weekend dates with the following:
Handheld Leaf Blower
Troy-Built ChipperVAC
12X20 tarp
Hand Rake
Due to the various trees, oaks, maples, beech, they all drop the leaves at different dates.
I usually blow toward a pile, then vac the rest. then pull the pile to a dumping area, mulching what is left.
Kind of ryhms, don't it?
/w3tcompact/icons/smile.gif
-Mike Z.
   / TBN Poll - Best Leave Removal Method #7
Well if Santa Cluas is generous & gets me the bucket forks I asked for, next year I'll build a big box (I like Boondox's chicken wire lets the air go somewhere) with the front open & blow them into that.
For now, I blow them into a pile, tarp 'em & haul to the compost pile. I've found that having the wife help me carry the tarp is easier on it than dragging with the tractor.
   / TBN Poll - Best Leave Removal Method #8
1 rake away from house
2 drop a match
3 watch the pretty flames dance through the leaves
Course I don't get new imlements this way
Why is this thread in KOO?
   / TBN Poll - Best Leave Removal Method #9
<font color=blue>Why is this thread in KOO?</font color=blue>
Wondering the same thing myself. /w3tcompact/icons/grin.gif
Considered moving it to Rural Living, but leaf gathering is not unique to country homes. We spend a good number of hours raking/blowing/disposing of leaves here in subrubia, too, so let's make it one of those ongoing Projects.
   / TBN Poll - Best Leave Removal Method #10
Actually, I thought the thread was posted in Kubota Owning Operating (was it?)
Projects is just fine....
Bef-Co Finish Mower - INOPERABLE/PARTS ONLY (A52128)
Bef-Co Finish...
2006 Pearson Quantum Fire Truck (A50323)
2006 Pearson...
PORTA CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTA CABLE 150...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
2014 CATERPILLAR CB54 XW SMOOTH DBL DRUM ROLLER (A51242)
2014 CATERPILLAR...
Western Snow Plow with Brackets (A50515)
Western Snow Plow...
