TBN BRAIN TRUST needed. .HOW to stop storm drains clogging with leaves & branches?
   / TBN BRAIN TRUST needed. .HOW to stop storm drains clogging with leaves & branches? #1
coffeeman
Platinum Member
Hi
I have a run off from springs along my driveway. They are bone dry for last couple months. When we get big thunderstorms, the rain & spring run down into 2 15 inch pipes. They are big enough until a few branches & leaves clog pipe. I can put new 24 inch pipes in place and should be good. PROBLM: Pipes cost $425 per 10 feet. I need 70 foot of pipes X 2. Total cost just for Pipes $6000. 2nd PROBLEM: can't shorten the pipe run because gas company must be able cross the water to tend to a small gas well. Gas Co says they need 70 foot in case they have to take a rig in to well for repairs. Since 2007 there was never a problem. All they need is enough room for 1000 gallon water truck. Gas well company not interested in helping. Just started talking to Gas Co, though. The original driller has gone bankrupt.
Any ideas on how I can catch rain water in storms without clogging? In bigger thunder storms when drains clog and flow down driveway sometime get a 1/4 mile of driveway washed out in an evening. What kind of hook up could can I make that would catch heavy water and protect drain from clogging & Keep branches, leaves etc. away from causing trouble. This summer is least amount of rain in years. But, I dread Spring because of rain & snow melt. I"M hoping there might be simple way to solve problem.
You all have nice evening and BE SAFE..........Coffeeman..
   / TBN BRAIN TRUST needed. .HOW to stop storm drains clogging with leaves & branches? #2
Re: TBN BRAIN TRUST needed. .HOW to stop storm drains clogging with leaves & branches
I’ve seen more problems with grates than they help. They stop up and block the pipe and then you’ve got a washout problem.
   / TBN BRAIN TRUST needed. .HOW to stop storm drains clogging with leaves & branches? #3
A 24” pipe had 2.5 times the area of a 15” so it wouldn’t need doubled. And you could probably sell the 15” to help offset the cost. Do you have enough height to cover a 24” without burying it below the water grade?
   / TBN BRAIN TRUST needed. .HOW to stop storm drains clogging with leaves & branches? #4
Pictures of your pipes would help.
Would any of these work?
culvert debris guard - Image Search
   / TBN BRAIN TRUST needed. .HOW to stop storm drains clogging with leaves & branches? #5
How much room do you have in front of the inlet? One of those beaver screens in faxman's link should work. If you can have a small "pond for lack of a better word" you can put a barrier at water level and allow the water to come up underneath the debris and into the drain.
   / TBN BRAIN TRUST needed. .HOW to stop storm drains clogging with leaves & branches? #6
Well - when we figure it out - I'll pass it on to our city public works dept. At least twice a year we get wild, torrential rains. Main street is the low point thru town. Man, does it ever flood out Main street. City crews are out pulling grates and wrenching out crap to clean the storm drains. The main "plugging agent" - leaves, dirt & mud.
Makes a good under car wash. At the right speed - clean out the wheel wells and the entire underside.
   / TBN BRAIN TRUST needed. .HOW to stop storm drains clogging with leaves & branches? #7
Is it an open ended pipe or more of an inlet with a grate? 4570 man is correct also, a 24”pipe would carry more water than twin 15” pipes.
   / TBN BRAIN TRUST needed. .HOW to stop storm drains clogging with leaves & branches? #8
If the 15" pipes carry the flow sufficiently, I would recommend a trash rack. Like 4570 said, a screen at the inlet of the pipe will simply clog, but a trash rack around the inlets should keep the larger sticks and such from clogging the pipes. Still a maintenance item, but you won't have to babysit it as much.
   / TBN BRAIN TRUST needed. .HOW to stop storm drains clogging with leaves & branches? #9
What I often see is a pit B4 the uphill opening that catches most debris that would clog the drain pipe.
Said pit however needs periodic cleaning.
Also on steep runs they like to line the ditches with large (3-4") crushed stone that deters fine muck from clogging drain pipes.
   / TBN BRAIN TRUST needed. .HOW to stop storm drains clogging with leaves & branches? #10
The only thing I've is like holding pond with a screen over flow riser in the middle
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2015 FREIGHTLINER...
2007 Ford Escape XLT SUV (A51694)
2007 Ford Escape...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
2021 Bobcat S740 (A50123)
2021 Bobcat S740...
2014 John Deere 644K Articulated Wheel Loader (A51691)
2014 John Deere...
KUBOTA ZD1211 (A53084)
