Taskmaster tractor hydr
   / Taskmaster tractor hydr #1
Grandpa Oregon
Reedsport,Oregon
Taskmaster Trooper
My Taskmaster Trooper 425A tractor lost it's hydraulics completely. I do not have a manual on it and hoped someone would know where I might get one or where the filter is on the hydraulic system,which is what I am told to start with. Any suggestions would help as I am not a mechanic.Thanks a lot, Bruce
   / Taskmaster tractor hydr #2
Not familiar with your tractor but starting at the pump shaft splines (if it has an aux hyd pump would be a great place to start)....make sure the pump shaft is turning
Do you pix of the pump or hyd system??
   / Taskmaster tractor hydr #3
http://www.jlaforums.com/viewtopic.php?t=124599185
Check your fluid levels, check or replace the filters.
Check filter screen if reservoir has them.
Check the suction tube.
Remove a hose from a cyl and place in a bucket to check flow, color of fluid. If there is water in the system, the fluid will be milky/muddy looking.
Check to see if pump is turning. The data page says the tractor has two pumps.
Cub Cadet Kohler mower 7000 series (A50324)
Cub Cadet Kohler...
2020 Brenner 450 Gallon Skid Mounted Vacuum Tank (A52377)
2020 Brenner 450...
UNUSED Jack Lift 5/10 Ton (A53117)
UNUSED Jack Lift...
2022 Forest River Cherokee Grey Wolf 26BRB Patriotic Edition 32ft. T/A Travel Trailer (A51694)
2022 Forest River...
2003 Walk-Behind Automatic Seed Spreader (A54811)
2003 Walk-Behind...
