Tale of the tape.
   / Tale of the tape. #1
Farmwithjunk
Super Member
Mt Washington, Kentucky
Where do I begin.....
Need a "field measurement". I'm looking for a couple front tires/wheels to level a tractor that's had bigger-than-stock rear tires added. I need to raise the front a couple inches.
OK. We start with 6.00X16"'s that measure 28.1/4". Firestone data book says 7.5L X 15" is 30.5" tall. (7.50X16 WAAAAAAAAAY too tall) The same book says my 6.00X16"'s are 29.25. (and I know that isn't accurate)
Anyone have a tractor with 3-rib tires, 7.5LX15"s, and could throw a tape measure on 'em for me. (Tractor currently has 6"X16" rims. I have a set of 6-lug, 7"X15" rims. That's what FireStone says the 7.5LX15" needs) Just don't want to buy $140 worth of tires only to find they aren't any taller than what I have.
   / Tale of the tape. #2
Tire data book specifications are manufacturer specific. Specs do vary, sometimes quite a lot, between different tire makers. In addition, the specifications in data books are with the tire inflated on the proper wheel. There is often a significant difference in mesauring an inflated tire versus an uninflated one.
Would a tire 29.25" suit your needs? If so, all you have to do is buy the Firestone that is specified that dimension in their data book.
You do understand that if you go with a tire like a 7.5L-15 you will also have to buy different wheels? Your tractor currently has 16 inch wheels whereas the 7.5L-15 would go on a 15 inch wheel.
Edited to say DUH! I see you already have 15 inch wheels.
   / Tale of the tape. #3
My SIL and daughter just sent me an adobe file of the Goodyear Farm Tire handbook. I presume they got it from the web somewhere. It's well over 100 pages of useful stuff just like what you're looking for. Maybe you can google around a little and find it. It might have something that Firestone doesn't have in theirs.
As another thought, maybe you need a two rib instead of a tri-rib with the high center rib?? Another thought -- Titan makes the 6 or 7 x 15 R1s on the back of my Kubota. Don't know the height of them or how desperate you are. One of my 8Ns had truck rims on the front, complete with brake drums, to carry some 6 ply truck tires that were 15s. The old 6 plys were/are something like an 83 aspect ratio, way taller than newer style tires. I think modern design tires get no taller than 75 aspect ratio.
   / Tale of the tape. #4
Have you actually discussed this with the tire dealer ? or just info from the book?
   / Tale of the tape. #5
The tires with the "L" such as 7.50L-15 versus 7.00 or 7.50- are different aspect ratio. I have always presumed the L stands for low profile as the "L" tires are much wider and require a much wder rim in most cases.
   / Tale of the tape.
I posed the question to 3 different tire dealers that deal heavily in AG tires. Only one could give me any usefull info. Others didn't even know what BRAND of ribbed tire they sold.
Listed sizes from Firestone and Titan vary from what we already know as fact. (Both wrong by over 1" on 6.00X16's) I WANT something close to 30". Would LIKE to have 1-2" wider than the 6.00. 7.5LX15 looks like the prime suspect.
My Massey has 14.9X28 rears. It came with13.6X28's. The 14.9"s are almost 4" taller than 13.6"'s. I'd like to raise the front some, but not a lot. 2" to 3" dia. tire size increase would do it.
   / Tale of the tape. #7
If your tractor is 4WD, be very careful to have the fronts and rears at the proper ratio, otherwise, the lead / lag of the rears to front will be off. This can lead to early tire wear, and linkage wear to possible linkage damage.
Read this article from Firestone to help you decide what is correct.
Lead/lag
John
   / Tale of the tape. #8
Note also that mounted tire diameters depend on the width of the rim. The published data will assume a certain rim width. Go to a wider rim, the tire will be "shorter". Go to a narrower rim, the tire will be taller.
Also, it's really easy to underestimate the diameter of a mounted tire, when measuring with a tape measure. From the ground to the top of the tire isn't the diameter measurement cited in the literature--the measurement should be taken parallel to the ground, using a set of calipers (or an improvised approach....) This is the tire's diameter. The loaded radius is found by measuring from the ground to the center of the tire. If you measure from the ground to the top of the tire, you are actually measuring one half the tire's diameter plus the tire's loaded radius.
Another factor is tire pressure, even a few psi can make a difference (especially when mounted on a rim that's wider or narrower than the rim used by the manufacturer).
   / Tale of the tape.
My measurements are/were done with the tire and wheel laying flat on its side. Actual diameter.
In the case of the 6.00X16"'s, they're mounted on O.E.M. rims, 6" wide, and that's what all manufacturers suggest. I have a set of 15"X7" 6-lug wheels. That is what manufacturers suggest for (among other things) the 7.5LX15. I'd be comparing one tire (on correct rim, vs. another tire mounted on correct rim. Brands vary in size, but there's got to be a good "ballpark" # that'll tell me IF and by how much the 7.5L is bigger than the 6.00. If it's an inch or less, it's not worth the trouble.
Later model (year) Masseys came equipped with this tire/wheel combo. Can't find one to measure though.
   / Tale of the tape. #11
There is a link to the Goodyear Farm tire handbook in the thread about posting a large document. I think KiotiJohn posted it, maybe IslandTractor. Good reading, may be useful.
   / Tale of the tape. #12
Farmwithjunk,
I would take your tape measure to the dealer and measure a few tires of different brands. A big Ag tire dealer should have plenty to measure. This size difference is very common with tires. Start measuring truck tires, like 33's,35's, etc and you will be pretty surprised at the measurements, even as you say with the tire unloaded. In my experience I have found the Firestones tend to run larger in diameter than Goodyears for the same size tire. I would recommend checking out the Firestones and also if you drive by some tractor dealers, measure some tires. Just my 2 cents.
Good luck,
Russ
   / Tale of the tape. #13
If you know anybody with a 1755 Oliver you might be in luck. Many came with the 7.5-15 according to an old "Official Guide" book.
   / Tale of the tape. #14
From the Oliver board on ytmag: 29.2 on Firestone and 29.3 on Goodyear.
   / Tale of the tape.
Sounds like I have the answer I was asking for. Thanks. They're not much different from the 6.50X16's that I have now. Found a set of "off-brand" 7.50X16's that are shorter than some I've measured. 3" taller than 6.00's. Might try that route. Gotta find a couple 6" or 7"X16, 6 lug wheels.
It's never over.........
   / Tale of the tape. #16
</font><font color="blue" class="small">( If your tractor is 4WD, be very careful to have the fronts and rears at the proper ratio, otherwise, the lead / lag of the rears to front will be off. This can lead to early tire wear, and linkage wear to possible linkage damage.
Lead/lag
John )</font>
Thanks for putting up that link, I never realized about lead/lag and how to calculate it.
   / Tale of the tape. #17
</font><font color="blue" class="small">( Thanks for putting up that link, I never realized about lead/lag and how to calculate it. )</font>
You're welcome. I first got onto it after reading that someone wanted to put larger tires on the front of his four wheel drive tractor. I knew that the ratios would be thrown off, but didn't know exactly how to tell him of the dangers. I found this link and thought it explained it very well, and probably saved the guy a lot of troubles.
John
2015 Peterbilt 389 T/A Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 389...
Hydraulic Liftgate (A59230)
Hydraulic Liftgate...
2022 FORD F-250 STX CREW CAB TRUCK (A59823)
2022 FORD F-250...
2022 CATERPILLAR 303.5CR EXCAVATOR (A60429)
2022 CATERPILLAR...
Black Jet Dock Drive-On (A59228)
Black Jet Dock...
2008 Godwin Dri-Prime CD103M Towable Trash Pump (A59228)
2008 Godwin...
