Takeuchi TL140 loader stops?
/ Takeuchi TL140 loader stops? #1
yohyatt
Grass Valley
Tak tl140
First post here - this has been driving me nuts. Also posted in heavy equipment
I just picked up a new Tak TL140, have a lot of clearing and grading to do with the recent fires that took out my neighbors homes in California and some of my property - seems like the taks are strong pushers...
I've been researching the heck out of 4n1 buckets - come to find out (watching a video on everythingattachments's - construction attachment 4n1), that the hitch height on the bucket needs to be different than most of the other CTLs.
So I called Construction attachements - found out that the loader stops won't engage if you have a hitch that his too high or too low - I went out and verified, turns out that the cat bucket that came with my loader is pretty close to 2 & 19/32 inches from the ground. They told me that you want the loader on the stops when pushing hard - makes sense, to take the load off the cylinders. Bobcat is 4 1/8 from the ground , case is 6 inches (meaning the buckets' hitch height for those equipment need to be that high off the ground) They are the ONLY ONE that I can find that cares about this -seems odd that no one else mentions this. I tried my neighbors skidpro 4n1, with a 6 inch height - soon as the bucket hit the ground - my loader was 2 inches still from the stops - so good example.
Does this matter when using other implements that you push hard? I just ordered a bad arse root grapple, all AR400, extra beefed up - planning on pulling, pushing, rooting, etc pretty hard with the 10k tractor. I get it regarding getting the bucket to sit flat and for grading.
2025 JMR 4x8 Forklift Safety Basket (A61572)
2025 JMR 4x8...
2012 Volkswagen Passat Sedan (A61574)
2012 Volkswagen...
2021 Kubota MX6000 (A62177)
2021 Kubota MX6000...
2014 Toro Z-Master 6000 Series 60in Zero Turn Commercial Mower (A59228)
2014 Toro Z-Master...
2004 Cadillac Eagle Ultimate Hearse, Eagle Coachbuilders, Hearse Collector Special (A63689)
2004 Cadillac...
Challenger 65C/70C/75C/85C Tractor Parts and Service Manuals (A63117)
Challenger...
