takeuchi TB 235 movement alarm and coolant switch function
   / takeuchi TB 235 movement alarm and coolant switch function #1
aasrs
NE GA
OMC Mustang 440
Hello, hope im posting to the right area, I have a 2008 tb 235 mini excavator, the movement alarm is running all the time whenever engine is running, the shop manual does not have a diagnoses or adjustment procedure listed, does anyone here have any experience with this setup?
also the water temp switch (not the temp gauge - its working) but the switch circuit that lights the light, how can I test that circuit, to the light, I know how to test the switch itself, but would like to test the circuit to see if the light comes on when it is supposed to do so
ground the wire with a tester does not light that light
thank you
thank you
tom
   / takeuchi TB 235 movement alarm and coolant switch function #2
For a light to come "on" it needs 12 volts and a path to ground.
If the light has 12 volts feeding it, then it's either not grounding when it should or its burnt, you "tester:",
( I don't know what kind of tester your using?) may not be grounding the light, some testers will not load the circuit, you "may" need to ground the light directly to test it.
2018 Bobcat T590 Compact Track Loader Skid Steer (A50322)
2018 Bobcat T590...
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A51039)
2021 John Deere...
2022 Massey Ferguson 1825E 4WD Tractor (A50860)
2022 Massey...
Guard Rail Joints (A48081)
Guard Rail Joints...
2021 Delta Redirective Crash Cushion 75000 (A49461)
2021 Delta...
2021 CATERPILLAR 416 BACKHOE (A50458)
2021 CATERPILLAR...
