takeuchi hates cold weather
   / takeuchi hates cold weather #1
goatman 1
Bronze Member
Murphy NC
Wheel Horse, Cub Cadet,Several Speedex's,Allis Chalmers, John Deere, Tuff-bilt, Power Mite, Bonanza, Power King, Bobcat Toolcat, Takeuchi Trackhoe
I've got a takeuchi tb 045 that will not start below 50 degrees, but above that, it starts and runs beautifully, and seems to have plenty of power. The engine is a yanmar 3 cylinder that looks nearly identical to my John Deere, except tha jd has glow plugsa dn the takeuchi has a grid type heater between the intake manifold and the breather hose. I have been tempted to use starting fluid, but most of my friends say not to, as the engine will become hooked on it. The engine "was rebuilt by the dealer" about 600-800 hrs ago, accordint to the man I bought it from.
Any ideas?
   / takeuchi hates cold weather #2
I have had many pieces of equipment with a device to auto shoot either from a button in the cab, keep in mind alittle shot will do ya!! However none of these were equiped with any type of heater,,,, a heater and either are BAD, if the heater cycles boom it ignites the either in the manifold,,,,,, I would check out the heater, if the manufacturer put it on, probably they would prefer that method to start a cold engine over either for good reasons,,, If all else fails find a 12v hairdryer plug it into a vehicle power port and preheat with that. Oh I think if ya check with the Yanmar tractor guys they will tell you either will eventually destroy the engine.
   / takeuchi hates cold weather #3
As mentioned, a air heater grid plus ignitable material may make for loud noises that could be expensive.
2018 Freightliner M2 106 Cab and Chassis Truck (A51692)
2018 Freightliner...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A51691)
2006 iDrive...
2005 Kubota M105S (A50123)
2005 Kubota M105S...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
2024 Cynergy Cargo 2 Enclosed Trailer (A53117)
2024 Cynergy Cargo...
