TAISHAN354C detailed parameters
   / TAISHAN354C detailed parameters #1
jacktractor
Banned
Main Technical Data of ZT35HPSeries Tractor
ZT354C model(35HP,4WD)is the gardening tractor which is developed for special requirement of American,European gardening feature.The tractorepuiqqed with multi-cylinder diesel engine,small bbor,Power steering,2stage clutch,shuttleshift,creeper,steamline fibre glass hood,whith characteristic of convenient&flexible operation,low nosie,European Iexhaust standard Engine. It could be mounted whit front loader and backhoe,also it can realize the quick-shift as a leisure tools for white-collar stratum..
Main Technical Datas
Tractor modol ZT354C
General Specifications
Type 4*4wheel
Rated traction force(KN) 8.3
Constructional weight(kg) 1440
kW P.T.O.Max Power(kW) 22
Front wheel Tread(mm) 1215
Rear wheel Tread(mm) 1150(adjustable)
Wheel Base(mm) 1840
Type F:6.5-16 R:11.2-2.4
Minimum Turning Radius(m) Wifh One-side Braking 3.8
With One-side Braking 2.9
Groud Clearance(mm) 330(Under front driving shaft)
Overall Dimensions(mm) 2910*1450*2335
Engine
Type Y485
Bore*Stroke(mm) ¢85*90
r/min Rated Pevolution(r/min) 2300
Rated Power(Kw) 25.7
Max Torque(N.m) 108
Speed of Max.Torque r.p.m 1610
Fuel Consumption(g/kwh) <=247
Lubricating Method Pressure and Splash Lubricating
Cooling Method Fored Water Cooling
Transmission
Clutch Two stage Dry Type
Gear Spur Gear(4+1)*2Compound Shaft
Woking Devices
Lifter Tilling Depth Control Draft Positional responsive
kN Max.Lifting Capacity >=4.96
Suspension Type Three-Point,I Type
r/min Speed of P.T.O(r/min) (540,1000)(750,1000)(540,750)
E-MAIL:leclxy@hotmail.com MSN: leclxy@hotmail.com
Type 4*4wheel
Wheel Base(mm) 1840
Engine
Type Y485
Bore*Stroke(mm) &#65504;85*90
Max Torque(N.m) 108
Transmission
Woking Devices
Cub Cadet Kohler mower 7000 series (A50324)
Cub Cadet Kohler...
1779 (A51248)
1779 (A51248)
2001 John Deere M665 (A50120)
2001 John Deere...
2016 Nissan Pathfinder S SUV (A50324)
2016 Nissan...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
PEMBERTON LR129-1123 RAKE ATTACHMENT (A53426)
PEMBERTON...
