Tactor Assisted Deck Move
   / Tactor Assisted Deck Move #1
TTTTTT
Bancroft , Ontario
Dong Feng 354 (Oct 2008)
Hi All,
In preparing for a cottage addition (which is now closed in and almost finished on the outside), I had to remove a section deck and move it to another part of the cottage. I did not want to totally dissemble it, so of course the green machine tractor was the perfect tool for the job. After cutting it apart from the existing deck and removing the anchor bolts..........
Deck Removed and location of addition
I then used the DF (with attached steel cable with the bucket hooks) to pull it away from its location and pull it around the corner of the cottage close to its new intended location. i was then able to lift the far end high enough to get a long log under the end that would go against the cottage. After maneuvering back to the front, I could lift the front end and roll it into position. I could then lift each corner at the cottage side and block it to the correct level
The Final Resting Spot
Next year I plan a small "mudroom" where the deck is. It will be rotated 90 deg. to accommodate the new location. It was great fun using all that power to good use and even without tipping over ;D. even better to justify its existence to my better half. :) ;)
Its been a very busy but fun summer building. I'll add a thread on the addition some time as well. Turning out real nice.
Thanks for viewing Dave
   / Tactor Assisted Deck Move #2
Nice job! I had a tractor assisted deck move too... with the backhoe... unplanned... wife was NOT happy. Oooops!
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
2005 FORD F350 XLT SUPER DUTY SERVICE TRUCK (A51406)
2005 FORD F350 XLT...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
2019 FREIGHTLINER SPRINTER 2500 CARGO VAN (A54313)
2019 FREIGHTLINER...
2017 Jeep Patriot 4x4 SUV (A53424)
2017 Jeep Patriot...
2015 Ford F-250 Ext. Cab 4x4 Flatbed Truck (A53422)
2015 Ford F-250...
