Table Height
   / Table Height #1
bigtiller
Super Member
central Iowa
John Deere 2720 John Deere 3039R John Deere Z545R
If winter ever ends, i want to build a nice welding table about 3'x 4.5' but I am not sure how high to build it. I am 5'11 &1/2" tall, weld mostly flat work and small (2x3) angle. My first thought was to go 36" high but after over thinking it for the winter i am left wondering if 32" would be better for the average 45 minute job. So....
How tall is your table and how tall would you like it to be?
   / Table Height #2
I'm only 5'6". My 36" table works fine for me. I would think that would be too low for you for most work.
My "next" one will be based on a hydraulic platform.
Terry
   / Table Height #3
36 is typical kitchen counter height. I am the same height as you and think it would be about ideal. Remember you have to be able to put the completed projects back on the ground when you are done also.
   / Table Height #4
I do all my work benches at 36" (I am 6'1"). It's always been a comfortable working height. A side benefit (if you wood work) is that most table saws are 36" high, so you can use a 36" work bench as an out feed table quite handily.
   / Table Height
I do that in the wood shop but i try to keep the metal work in a different building.
   / Table Height #6
Is a kitchen counter comfortable. They are 36". I once read in a work bench book to do this. Hang your arms by your side turn your hands out 90*. Palms down. That is your ideal height. I am about your size and works out to 34" for me. Your height is not the sole determining factor.
If your knuckles drag the ground,the lower the bench. Lizard limbs,taller bench.
2024 JOHN DEERE 1025R LOT NUMBER 106 (A53084)
2024 JOHN DEERE...
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A51691)
2008 Ford F-750...
2025 IR IRMC 8D UNUSED Massage Chair (A53117)
2025 IR IRMC 8D...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2008 Freightliner B2 School Bus (A51692)
2008 Freightliner...
