TA357/mf1160 won't start without a boost
   / TA357/mf1160 won't start without a boost #1
case685
Southwest Ont. Canada
Hi all, I have TA357-virtually the same as a MF1160. I've been having an issue with it not starting, when I turn the key I get a single click, fairly loud, not the weak ticking sound a low battery generally produces. This problem has gotten worse over the years, it only did it occasionally at first but now does it 99.9% of the time. If I boost it using my charger which has a boost feature it fires right up. The battery is good and I did replace the starter/solenoid.
Any thoughts or insights on what might be causing this and how to correct it would be greatly appreciated.
Thanks,
Gerry.
   / TA357/mf1160 won't start without a boost #2
Check battery cables and connections, look for swelling of the cables at the ends, if you se any corrosion replace them, all connections should be perfectly clean and shinny.
   / TA357/mf1160 won't start without a boost #3
My G-152 did the same thing, and after checking all the cables / connections, I discovered I needed to take the starter motor off and clean where it mates to the block, since that's how it's grounded. Fixed the problem completely. you might give that a try.
Thanks Guys, I will try those to see if it fixes the problem. I did play around with the fusible links-there's 4 of them-just wiggled them around mostly, and then it fired up but it was a one time thing, I haven't been able to get it to start again after that :(
   / TA357/mf1160 won't start without a boost #5
If its intermittent Sounds to me like a bad ground . Provide another ground cable . Engine block ,direct to battery or just jumper cable to test for continuity .Has to be a logical easy fix to this
Hi Guys
Sorry for the late update. I think I have the problem solved. My brother came over with his volt meter and found out there was a significant drop in voltage at the starter solenoid when turning the key. A closer examination showed the terminal on the solenoid was loose-turning it to the side a bit seemed to tighten it up and the tractor would start every time with it in that position-moving it back to center would loosen it and result in getting only the loud clicking sound. I moved it back to the side and epoxied it in place, hopefully that permanently takes care of the problem.
Thanks,
Gerry
Land Honor Quick Attach Accumulator Grapple (A50514)
Land Honor Quick...
10' Feed Bunk (A50515)
2017 John Deere 30G Mini Excavator (A50322)
2017 John Deere...
Bush Hog 287 3 pt Mower (A50514)
Bush Hog 287 3 pt...
1994 Peterbilt 379 Semi (A50514)
1994 Peterbilt 379...
Case Ih 1660 Combine (A50514)
Case Ih 1660...
