T7074 Rear SCV's
   / T7074 Rear SCV's #1
dcgrosvold
NW Arkansas
Montana T7074
Hi all -
I just bought a T7074 last fall and I'm enjoying it immensely. However, now that I've used the BB a few times, I have a question for those of you who have more hydro experience than I:
The T7074 comes with three rear SCV's standard. About the only thing I can determine about these from the manual is that the first two (A & B) are spring-loaded to return to neutral, and the third one (C) has a detent - but I can glean nothing else.
Does anyone on the list know if these valves are open center or closed center? Which of them would be good to use if I wanted to add Top-N-Tilt? Since I have the rear valves already, it seems like it wouldn't be too much expense to get the cylinders for the top and right lower links. I just want ot be sure I understand things correctly.
Thanks to anyone who might be able to explain this to a hydraulic noob. :eek:
JLG 1930ES ELECTRIC SCISSOR MAN LIFT (A51246)
JLG 1930ES...
Kinkaid 1200 LS-PH Towable Hydroseeder (A51691)
Kinkaid 1200 LS-PH...
PRO WORKS PWFF LOT NUMBER 156 (A53084)
PRO WORKS PWFF LOT...
2013 KENWORTH T370 DUMP TRUCK (A51406)
2013 KENWORTH T370...
John Deere MX 8 Brush Hog, 8', 3pt Hook Up, PTO  (A52384)
John Deere MX 8...
JOHN DEERE/UNVERFERTH 1700/330 LOT NUMBER 13 (A53084)
JOHN...
