T700 / mahindra 7010 tie rod end repair
   / T700 / mahindra 7010 tie rod end repair #1
DK35Hoe
Lanse,PA
Kioti DK35
Has anyone found a repair to fix the tie rod ends on a t700, mahindra 7010, or Montana T7074? There is an old thread where a member said he had a fix but didn稚 list it and he痴 been inactive for a few years.
The bolt in the tie rod is too small for the hole and you can稚 tighten it easily, and when you do it just works loose since the mounting hole is too small.
   / T700 / mahindra 7010 tie rod end repair #2
Any pictures? Is it a factory new end..
I didn稚 purchase the new ones yet, I have read a few posts of issues with this model of tractor having the larger hole than the new tie rod end. I figured I would see if someone already has a fix before I waste money on new tie rod ends. I知 thinking either a larger tie rod from another application or have a bushing made for a new tie rod.
2008 FORD F550 XL SUPER DUTY DUMP TRUCK (A51406)
2008 FORD F550 XL...
UNUSED GREAT BEAR 1.5CY SELF DUMPING HOPPER (A51248)
UNUSED GREAT BEAR...
2023 JOHN DEERE 8R310 LOT NUMBER 203 (A53084)
2023 JOHN DEERE...
20ft Driveway Gate (A51573)
20ft Driveway Gate...
UNUSED CFG QUICK ATTACH HYD POST DRIVER (A51248)
UNUSED CFG QUICK...
2014 Ford Taurus SE Sedan (A51694)
2014 Ford Taurus...
