T5C Outrigger cylinder
   / T5C Outrigger cylinder #1
stendek
Darlington, MD
Terramite T5
I have an outrigger cylinder on a 1997 T5C I need to replace because the housing is cracked and leaks oil. Does anyone know where I can get a replacement and the part number?
Terramite wants $315 for a factory cylinder. Given its measurement (2" bore, 12" stroke, 20" closed, 1" pins) I can find several cylinders that would fit and work just fine for around or under $100, however, everything I can find has 2.75" cylinder end sleeves (which would work) and 2.25" rod end sleeves. On the rod end it needs to be 2" or under. I could use a rod eye style cylinder but then the rod end would be 1.25" wide and I would need .75" worth of spacers.
I am leaning towards buying the sub $100 sleeve style cylinder and cutting .125" off each side of the rod end sleeve, but thought I would register on here and post the question first in case there was a good source of cheap cylinders I don't know about.
   / T5C Outrigger cylinder #2
Surplus center seems to be a favorite around here although thier price aren't any better than what you have already found. I have placed 10 orders with them over the last say seven years and been happy.
Surplus Center
I'd go the route you propose with the cheaper cylinder and sleeves.
   / T5C Outrigger cylinder #3
I think you won't have any problems cutting the sleeve narrower to fit, sounds like the way to go.
IH Cub Lo-Boy 154 (A50514)
IH Cub Lo-Boy 154...
STOP!!!! PLEASE READ ALL TERMS BEFORE BIDDING!!! UPDATED TERMS!! (A50775)
STOP!!!! PLEASE...
2018 Caterpillar 416F2 4x4 Extendahoe Loader Backhoe (A50322)
2018 Caterpillar...
Kubota RTV500 (A47384)
2014 JOHN DEERE 35G EXCAVATOR (A51242)
2014 JOHN DEERE...
2017 UTILITY VS2RA 53FT REEFER TRAILER (A51222)
2017 UTILITY VS2RA...
