T5060 flashing caution light/ trouble symbol
   / T5060 flashing caution light/ trouble symbol #1
1340
Red Deer, Alberta, Canada
John Deere 2950/New Holland T5060
I picked up a used T5060 this summer.
Now the caution light comes on and flashes 4 times, goes out, shows a trouble symbol, that goes out, then the caution light comes back on and stays on. The symbol shown is a circle with a drop in the middle. On either side of the circle is a short line at 9 & 3 o'clock that matches the curve of the circle.
There is also a straight vertical line on the left side starting about 11 o'clock, drops down to the centre of the circle, and has a small triangle on the end pointing to the centre of the circle.
I was wondering if anyone has an idea what the symbol means. The closest l could find was brake boost pressure low. I think that is for air brakes which I'm pretty sure l don't have. I think that is a European system.
I called the dealer and they have no idea what it means. I will try another dealer, but want to ask here also.
No leaks under the tractor and I did check the brake master cylinder. Both levels were above the minimum mark.
I 'd like to get this solved so l can start using the tractor again.
Sorry for the long post.
TIA.
   / T5060 flashing caution light/ trouble symbol #2
I'm pretty sure it is the Brake Fluid Level light. The 2 outside curved lines represent brake shoes, and the drop is fluid. The line on the side with the arrow at the lower end would indicate low brake fluid.
   / T5060 flashing caution light/ trouble symbol #3
yes brake fluid , I had that one a week or so ago kept checking fluids filters and nothing would work . finally broke out the book and brake fluid was the culprit
Well done!
It appears you are correct.
I found the exact symbol l have in an online T6010 owners manual.
Brake Fluid Level low.
I didn't see it in my manual though.
Thanks for the info.
PREVIEW DATES AND TIMES (A51573)
PREVIEW DATES AND...
2013 CAT 950K WHEEL LOADER (A52472)
2013 CAT 950K...
3 Point Hitch Boom Pole (A51573)
3 Point Hitch Boom...
GENERAC ST20-S 2IN WATER PUMP (A52472)
GENERAC ST20-S 2IN...
