Tractor News T5 coming with Autocommand?
   / T5 coming with Autocommand? #1
Tonkatoys
Bronze Member
New York & Maine
2012 Deere 4720. 2012 Cat 305E CR
Read a rumor somewhere that someone high up at New Holland mentioned to the press that a new T5 is in the pipeline with an AutoCommand transmission like the T6 has. Might be introduced in France Ag show. If so this would be very interesting.
   / T5 coming with Autocommand? #2
What does the autocommand do?
   / T5 coming with Autocommand? #3
I bought one back in November, T5 115. Auto command. Sweet ride
   / T5 coming with Autocommand? #4
Auto command is the transmission type. Look it up on you tube. Good discription of how it works
I think you bought a T5 with Electro Command not Auto Command. There is a considerable difference. The auto command is like the ivt on the big Deere tractors. It's an infinitely adjustable transmission with no set gear changes. All automatic. This possibility is exciting for me since the smallest tractor it's available on so far is the T6. I'm not sure I want that much tractor, but a t5 would be awesome.
   / T5 coming with Autocommand? #6
I stand corrected . Read it to fast But i do love the electro command. Going to look into the t.6 though
   / T5 coming with Autocommand? #7
What is the difference between the auto command and the CVT transmission?
   / T5 coming with Autocommand? #9
Auto Command may be ok for larger tractors/ higher horsepower where you are working hour after hour at a constant speed like plowing, discing or mowing but for back and forth work like moving piles of sand, gravel or dirt the transmission has some problems. I bought a brand new Boomer 3050 in 2014 with the CVT transmission and sold it 11 months later after three incidents where someone could have been injured or killed. Since the CVT does not have a manual clutch it does not react properly when the engine is put under maximum stress and will suddenly go into a " safe mode" where the transmission is in a self imposed neutral. At that point the driver has to turn the engine off and then back on to re- boot the computer to get the transmission to work. This is dangerous when you are rolling down a hill backwards and into 30 feet of water. I upgraded to a NH T4.75 and will never own a tractor with CVT again. I have owned and operated 16 tractors in the past 46 years and have never had such a dangerous unit. CVT can also go into " safe mode" while moving forward into a pile of gravel/ dirt and buck so hard it can literally throw you out of the seat if not wearing the seat belt. I had it go into " safe mode" another time while having a 850+ pound limb lifted 8 feet above the ground. Yes, you have the option to turn the " safe mode" off but then the engine stalls when put under stress. No more Auto Command/CVT for me if these are in fact a similar transmission. Below is a picture of the day the Boomer 3050 with CVT left the property and the T4.75 with 12X12 transmission arrived....
I may be wrong but I think the transmission you had in the little tractor was a hydrostatic transmission not a cvt. It was most likely a very similar transmission to the Ehydro on my little John Deere. The Auto Command (New Holland) IVT (Deere) or CVT (case) are all similar and I believe based on dual clutch mechanical transmission that is controlled by a computer.
2003 VIKING  CEMENT MIXING TRAILER (A45046)
2003 VIKING...
2015 Chevrolet Tahoe SUV (A42744)
2015 Chevrolet...
2014 Towable Speed Limit Radar Sign (A42742)
2014 Towable Speed...
2014 UTILITY 53X102 DRY VAN TRAILER (A43004)
2014 UTILITY...
Cummins Turbo Diesel Engine with Transmission (A44571)
Cummins Turbo...
2019 VALTEK 2500HP FRAC PUMP (A45333)
2019 VALTEK 2500HP...
