T4050 Questions
   / T4050 Questions #1
SDT
Veteran Member
SE Indiana
Multiple Fords and Kubotas
Today, I bought a T4050 Supersteer, which will necessitate disposal of at least 3 or 4 of my (very good) vintage red and grey Fords sometime in the not so distant future.
With the 4050, I bought an 820TL FEL as well as a front weight package (6 weights) to counter balance a 10 or 10 1/2 foot mounted mower that I will use on some very steep ground. Does anyone know if the front weight bracket, which apparently bolts to the front differential casting (with or without the 6 weights), can be left in place when the loader is installed?
Secondly, my tractor has 16.9R30 rear and 11.2R24 front rubber. In order to lower the center of gravity a bit, I am considering swaping these for 16.9R28 rears and 12.4R20 front wheels/tires. My dealer has agreed to do this without charge if I so choose.
My question is: Sometime in the future, when I sell this tractor it is likely that the buyer will buy it as a hay tractor. Will the slightly decreased ground clearence resulting from the smaller diameter wheels/tires make it less useful as a hay tractor or otherwise lessen its resale value?
Thanks in advance.
Dean
   / T4050 Questions
Thanks, Rick.
I saw your post on YT and appreciate your advice. I may leave the loader frame in place sometimes while mowing but will likely remove it most of the time simply because it is so simple and will help with visibility. Maybe I'm becomming spoiled with this new fangled stuff. I did grow up on an AC WC with hand brakes and no hydraulics.
SDT/Dean
80in HD Tooth Bucket with Side Cutters (A51039)
80in HD Tooth...
2017 terex warrior 1800 screener (A50322)
2017 terex warrior...
1992 GROVE AP-308 CRANE (A51222)
1992 GROVE AP-308...
UPDATED INTERNET BUYER'S PREMIUM TERMS (A50774)
UPDATED INTERNET...
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A51039)
REYNOLDS 100 - 8...
2022 John Deere S780 Combine (A50657)
2022 John Deere...
