T4.75 with Cab Overheating
   / T4.75 with Cab Overheating #1
lowellcantrell
West Liberty, KY
Kubota 6800 4WD
2014 Powerstar T4.75 with Cab overheats everything AC is on while running at 2000 rpms or higher. Screens, all coolers, and radiator washed everyday (screens cleaned multiple times). Coolant flushed and replaced. All filters and fluids replaced annually.. AC is cold, but engine overheats. I'm thinking there is too much garbage in front of radiator ( AC cooler. Transmission cooler, Fuel line cooler, AC filter and housing). Thought about adding extra fan, but I would have to cut a hole in the hood because there is no room under the hood. Any other T4.75 owners have this problem? Any ideas how to correct the situation and eliminate engine overheating?
   / T4.75 with Cab Overheating #3
I found a very slight seep around an oil cooler clamp by the radiator and years of dust stuck to it blocking off 1/4 of the coolant radiator with a hardened mud. I couldn't see the blockage until I separated the radiators and was able to pressure wash the fins. I bet I washed a cup of dirt out.
   / T4.75 with Cab Overheating #4
never ran into this problem with mine. I've had a leak, because the hose clamp wasn't tight, but that's it. I can work all day with AC on, mowing fields with the screen half full of crap. I'd take the thermostat out and check it for proper operation, other than that gotta be the radiator or the water pump.
   / T4.75 with Cab Overheating #5
Or as suggested, a load of debris between the condenser, oil cooler and radiator.
Some folks do not understand how to slide the front unit clear of the radiator.
   / T4.75 with Cab Overheating #6
Are you washing the rad with water? I find it better to blow out with air vs water. Water ends up being a dirt magnet and the rad fins get plugged with cemented dust.
   / T4.75 with Cab Overheating #7
It's a six year old tractor, how long has it been an issue?
If it has just started this year something has changed.
Separate the stack and check each one separately use some coil cleaner or soapy water to clean each.
KSI Conveyor (A52748)
TITAN - SET OF 18.4R46 NEW AG TIRES (A52748)
TITAN - SET OF...
2006 Hino 268 Truck, VIN # 5PVNJ81T962S11110 (A51572)
2006 Hino 268...
2021 CASE IH 345 (A53084)
2021 CASE IH 345...
2020 Peterbilt 520 Truck (A51692)
2020 Peterbilt 520...
