DieselMonk
Platinum Member
- Joined
- Dec 9, 2004
- Messages
- 761
- Location
- Nova Scotia
- Tractor
- New Holland / T4.75 Powerstar & Boomer 1030, Case 580 SM II, Mahindra 1526
My T4.75 Powerstar with EHSS is leaking hydraulic oil only while driving somewhere around the hydraulic oil filter. Can't see anything much else wrong. Cleaned the filter operated the loader and it seemed all good. Started to drive the tractor around and sure enough it's leaking oil again. I took the filter off and it was humming tight on there. I mean so tight, it crushed the filter trying to take it off after 15 mins. The filter itself has no rust of any kind and the seal is not cracked or anything. The oil ring however feels kind of hard. The filter was changed 2 years ago and only has 100hrs on it. Not sure what to think unless the filter was put on too tight and crushed the seal? I guess I have to wait until I get a new filter installed and see if it is still leaking after that. The leak was so bad, that you could see trails where I went and where the tractor was parked there is a puddle. Pulled the dipstick and it was bone dry. I am guessing I've lost about 7 or 8 quarts or so.
Question is: Can a hydraulic oil filter leak oil out of the seal only while the tractor is driven?
