DieselMonk
Platinum Member
- Joined
- Dec 9, 2004
- Messages
- 761
- Location
- Nova Scotia
- Tractor
- New Holland / T4.75 Powerstar & Boomer 1030, Case 580 SM II, Mahindra 1526
Soo guys... here I am again... been a while, but things are busy. This is my second 2013 T4.75 12x12 with only 160hrs on it and I got transmission problems again, but this time it is different. My chore was to bring in 8 cords of firewood from the wood pile with the front loader and dump it down a chute to the furnace room in the basement. So I go High range up to 3rd gear either in forward or reverse (didn't bother turning around each time) as its only like 500ft to travel. Had about 60% of the 8 cord of wood already dumped in the basement, about half way to the wood pile in high range 2nd gear, I hear a noise as if a cable let go that operates the loader or the range shifter. I can shift all gears and all ranges but when I put the transmission in park, the tractor rolls away as if it is in neutral. Had the mechanic down and to my surprise the cable is actually good, but the leaver on the tranny that would lock the transmission in park turns around freely! What must have happen is the pin inside the transmission broke off and went through the gears... the noise would be sounding the same than I heard. Luckly I still have 1 month warranty! So my dealer is picking this week my tractor up for repair.
My question is: Does anyone with their 2013 T4.75, 3.2L with a 12x12 have any tranny problems (besides the usual blah blah like can't shift in and out of Park because of an adjustment)? This is my second one... DANG IT!
