T4 110 PTO Seal Leak
   / T4 110 PTO Seal Leak #1
johnny787
NC
Mahindra 6010
I have a t4 110 and my PTO seal is leaking. I have the PTO where you can interchange the shaft with the snap ring from 540 to 1000. Its leaking out of what appears to be the center of where that shaft goes in. Ive looked around for diagrams to no avail.
Couple of questions:
1. Does anyone have a diagram? The ones I found on messicks do not match with the interchangeable shaft
2. When I do go to change the seal, I assume I have to take the entire cover off to access it? It looks like 6 bolts and 2 hard lines?
I appreciate any input on this. The tractor doesn't have but 1800 hours on it.
   / T4 110 PTO Seal Leak #2
Were you able to find anything on this? What did you end up doing? How much had to come apart? I'm having same problem with our T 490 with 540 pto.
2017 Nissan Rogue SUV (A50324)
2017 Nissan Rogue...
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
Case 480E (A50120)
Case 480E (A50120)
2003 Doyle Semi Horse Trailer (TITLE) (A50774)
2003 Doyle Semi...
2014 Dodge Avenger Sedan (A50324)
2014 Dodge Avenger...
